Sponsored by: CARiD
greasing drive shaft
Old May 4, 2008 | 06:39 AM
lindkenth's Avatar
Want to know what to look for to grease the drive shaft to stop thumping noise. Where is the fitting located to lube?
Old May 5, 2008 | 10:11 PM
P. Bauer's Avatar
The "zerk" fittings are located at the joints of the driveshaft(s)
Crawl under the truck and locate where the driveshaft exits the transmission. There will be a u-joint there and inside this joint will be a zerk fitting. Also, mid-way down, another joint, another zerk. And where the shaft goes into the rear diff, another joint, another zerk.
For 4WD, look for the same thing from the transfer case forward.
You will need a grease gun, grease and a standard size grease tip for the zerk fittings.
Old May 20, 2008 | 11:05 AM
csharp100's Avatar
If you have a thumping noise, simply greasing will probably NOT take care of the problem. The first question I would be asking is WHY is there a thumping noise. Chances are it could be the need of a new u-joint. Greasing a worn u-joint will not fix your problem.
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
