Best way to upgrade my 88 Pickup 4wd? - YotaTech Forums
Go Back  YotaTech Forums > Toyota SUV & Truck Tech > Newbie Tech Section
Reload this Page >
Old 11-16-2018, 04:17 PM
abaddon11b's Avatar
Exclamation Best way to upgrade my 88 Pickup 4wd?
Hi everybody im looking to upgrade my 88 pickup i recently purchased 2 weeks ago, i want it to be last the rest of my life. how should i upgrade? ive been told to completely switch to diesel, approximately how much would such a thing cost?
i have mechanics in my family who i trust but will still charge me just as much as anywhere else.
if anyone has the time to respond to me and tell me whats best for this truck id greatly appreciate your time
im sorry this post might not make sense, im new to this, i need help just dont know where to start.
abaddon11b is offline
Old 11-16-2018, 04:28 PM
abaddon11b's Avatar
Story
Purchased the truck it ran fine but was extremely bumpy due to the large bald tires. i drove it to Houston 90 miles when the tire blew on me and i had to get it flat bedded to my home.
the next morning the truck was having trouble turning over. misfiring, i left it alone and looked up the best price for some new shoes.
the following day i had the tires put on and a diagnostic done to the truck. the intake tube had leaks. it was replaced and the truck has had no problems since.
the rear is welded so id like to have that replaced. so i don't run out of tires so often
however ive been playing with the idea of putting a diesel engine in and want to know what that all would cost. or to even find out if it is worth it.
please help me, im not educated in this field but with your help i can be as i am passionate about it and finally have the time to be. thank you in advance for your words and time.
Old 11-16-2018, 05:44 PM
You don't say how you plan to use the truck.. Daily driver?? Weekend wheeler?? Both worlds??? 6 cyl. 4 cyl???? Auto, manual tranny????
Get that welded rear end out of it, for sure.
millball is offline
The Following User Says Thank You to millball For This Useful Post:
abaddon11b (11-19-2018)
Old 11-16-2018, 10:48 PM
SomedayJ's Avatar
Pics!
SomedayJ is online now
Old 11-19-2018, 07:01 AM
If it has a 22RE, KEEP IT.
If it has a 3.0 V6 - consider a 3.4l 5MG swap. (because if you have to ask... that is the easiest. Still entails wiring harness and a LOT of electrical stuff.
Remove welded 3rd.
Remove that crazy lift.
Get some 3.75" backspacing steel hole rims and 33s.
That alone will make it so darn good. Can't imagine driving that Ford brotruck from the 80s look alike monster. No Diesel gonna help you there. :p
ev13wt is offline
The Following User Says Thank You to ev13wt For This Useful Post:
Old 11-19-2018, 08:39 AM
abaddon11b's Avatar
i want the best of both worlds. i plan to use the truck to move wood and whatever needed when i buy a piece of land in the future. so i want to be able to drive it on the road without issue and use its 4X4 capabilities when needed. its a standard v6 3.0. thank you for your quick response! how much would it cost to get the welded rear diff replaced, and is it worth to switch to diesel engine?
also, can i add an album to the conversation, i have all the pictures of my truck in an album.
thank you all for taking your time out of your day to help a dummy. im an uneducated infantryman trying to educate myself, thank you again!
Old 11-19-2018, 08:42 AM
abaddon11b's Avatar
Remove welded 3rd.
when i was stationed in hawaii this is the look that everyone had to handle the terrain out at the offroad areas. i like the look. thanks for the help tho
Old 11-19-2018, 08:54 AM
SomedayJ's Avatar
Nice truck!
Those tires are very heavy IMHO, you go from 0 to 60 mph in 35-45 minutes with those, I guess.
Old 11-19-2018, 09:10 AM
abaddon11b's Avatar
Originally Posted by SomedayJ View Post
Nice truck!
yes i dont go too fast, i dont mind it, however if its a performance issue then they have to go. does it hinder anything other than speed?
thank you for your time
Old 11-19-2018, 10:18 AM
SomedayJ's Avatar
If you like the look of it, that is a reasonable, it's your truck. I like to put 33"x10.5r15 in mine, and I'll need to re gear with those. If I remember correctly, the bigest tires I can install to keep almost the factory performance with the original gears is 31"x10.5r15 (don't quote me on that).
There are other components that 'suffer'with bigger tires besides the performance and fuel consumption, read this article to have a quick idea:
https://www.aamcocolorado.com/increa...-transmission/
Anyway, it depends what you want to do with your truck and the money you want to spend to mod it. If this truck's you DD, how many miles you plan to drive everyday, the kind of road and terrain, etc. There are so many variables. You want an diesel engine, it sounds good to me. Can you justify the swap? If you can't but you don't care to spend that money, it sounds good too. I think you need a plan before taking any action, but what you need right now, if you plan keep driving the truck daily, are safer tires, you already blew one, don't take more risks.
Old 11-20-2018, 01:27 AM
Hey, not knocking you for the look. I kinda think it embodies 80s USA tuning perfectly!
The steering angles are fubared, it is very top heavy, you are putting way too much strain on axles and CVs. If nothing has broken so far - and you haven't flopped it, you aren't trying hard enough.
You have "no" power, a hill on a freeway might as well be a giant wall.
Just trying to help - that truck is not made for those huge rims
ev13wt is offline
Old 11-20-2018, 09:11 AM
jakey poo's Avatar
Like a few have already said, those rims are going to wear your steering components out faster than a 5 cent lady of the night on payday. But to each their own. I would defintely plan on budgeting to replace everything in the front end soon.
jakey poo is offline
95yoda
02-06-2018 01:26 PM
Ladwig23
12-21-2013 01:32 AM
waterdog
03-29-2008 07:14 PM
turboale
Off Topic Talk
12
03-03-2006 01:23 PM
AznSky
Off Topic Talk
01-21-2006 04:29 PM
Quick Reply: Best way to upgrade my 88 Pickup 4wd?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
