Sponsored by: CARiD
Stuck on Crankshaft removal
Old Mar 6, 2019 | 03:40 AM
MasterOfNone's Avatar
Have all the pistons out but am stuck on the removal of the crankshaft. The center main bearing cap will not budge. Both bolts are out and from what I can tell, the thrust bearings are what is keeping it in possibly?
How do I go about removing the thrust bearings and getting the last main cap out to remove the crank?
Im puzzled and cant find any info after lots of scouring online.
Thanks!
Old Mar 6, 2019 | 05:45 AM
millball's Avatar
Smak the cap sideways with a hammer and block of wood.
Old Mar 6, 2019 | 10:42 AM
NYHumpinUtah's Avatar
BFH
and wood block
Old Mar 6, 2019 | 11:39 AM
old87yota's Avatar
Or a decent sized rubber mallet.
Old Mar 6, 2019 | 12:18 PM
This worked for all the other caps but this center one will not seem to budge. Guess I’m being cautious with the force tho. It is just so tight to the crank because of those thrust washers. Do the trust washers need to come out first? Or do they come out once the cap is off?
Old Mar 6, 2019 | 12:48 PM
Try putting a 2x4 at each end of the crank and prying it up against the block
Never had one that struck before
Does the crank spin?
Old Mar 6, 2019 | 12:50 PM
millball's Avatar
It is impossible to remove the thrust bearings without removing the bearing cap first.
Old Mar 6, 2019 | 01:59 PM
millball
you sure about that? Mine, the cap had a relief on both sides that didn't go all the way up for the thrust bearings. Pretty sure they can't come out without taking the cap off. But, I could be wrong.
Old Mar 6, 2019 | 02:02 PM
millball's Avatar
Originally Posted by NYHumpinUtah
millball
Aren't we saying the same thing???
Old Mar 6, 2019 | 02:28 PM
Duh
Yeah, we are...... I missed the im part in the impossible
Sorry,
the_supernerd
Apr 3, 2015 09:57 PM
geoduke
Aug 10, 2011 08:31 PM
Turmel-9820
Jun 29, 2010 08:04 AM
colorado87
Jun 15, 2009 09:11 PM
Phx_Chick57
73
Apr 10, 2007 05:51 PM
