Sponsored by: CARiD
Need to know a part name, thanks
Old Dec 14, 2018 | 02:09 PM
nicksavage's Avatar
Hi, I need to find out what part this is. Of course autozone is the only one within 30 miles of me and they dont know. It's on top of the valve cover, it is white and connected to a grey box. The truck is missing but when I push on the white part with the wires it stops. So figured it is the white part or the grey. It is a 1994 tacoma 4 speed I think a 22r, this thing is so old I can't find anything that tells me. Thanks in advance and see pictures.
Old Dec 14, 2018 | 08:07 PM
az4x4runner's Avatar
I am no 22R-E expert, but I'd guess AC idle up VSV.
File Type: pdf
Old Dec 14, 2018 | 08:32 PM
nicksavage's Avatar
I think you may be right after looking at the part, thanks so much, at least you pointed me in the direction I needed to go.
Old Dec 14, 2018 | 08:49 PM
No problem. Here is some more info on testing the VSV. Also check out the lines for any cracks or leakage. I don't think this is a parts store part, probably Toyota only, eBay or salvage yard.
File Type: pdf
Old Dec 15, 2018 | 09:36 AM
RAD4Runner's Avatar
Originally Posted by nicksavage
... when I push on the white part with the wires it stops. So figured it is the white part or the grey.
Yes, a Vacuum Switching Valve. Most likely just a connection problem because those things seldom go bad.
Before you replace inspect the connector (white) and pins on both sides for any corrosion, loose connection, broken wire strands, dirt, etc. and test it like mentioned above.
rldunn84
Jun 6, 2016 01:03 AM
woodyth
Sep 30, 2011 03:17 PM
CynicX
Oct 1, 2005 08:06 AM
