Sponsored by: CARiD
Crooked compression fitting on fuel line
Old Feb 23, 2019 | 07:23 PM
chicago60647's Avatar
My fuel pump went failing on my '98 4runner, in order to drop the tank I needed to cut the line going into the fuel filter as the fittings were so stuck that I was rounding the nuts with a flare wrench.
I've never used a compression fitting before - I was wondering if someone could let me know if the fact that the fitting is not on square will be an issue. Sorry for the flash in the pic. Thanks for the help!
Old Feb 24, 2019 | 07:59 AM
75w90mantraN's Avatar
If it leaks that's the issue. May be able to bend the lines to make them align...
Old Feb 24, 2019 | 07:05 PM
dropzone's Avatar
Fossilized
It looks like it's on there square and someone bent the line.
you need a wrench on the center of the fitting and on the side you are trying to loosen.
only attempt to twist the side you want to loosen, not the center 'nut'
Old Feb 25, 2019 | 09:34 AM
ksti's Avatar
Are you using a line wrench?
Kamo_82
Apr 22, 2015 10:23 PM
Charlie9422RE
May 17, 2011 08:03 PM
ewong
Jun 9, 2007 07:27 PM
4Peanut
May 18, 2005 05:25 AM
4Peanut
May 16, 2005 08:29 AM
