Sponsored by: CARiD
1990 2wd Pickup replacement suspension
Old Apr 27, 2019 | 03:49 PM
MasterOfNone's Avatar
Have spent so much time scouring the forums and google with no luck.
My suspension is old, tired and sagging and it’s tjme to replace.
—- 2 options —- unsure yet which route to go
stock height
small lift 1.5” - 3”
Having trouble finding good quality parts for either option but would like
-Leaf springs/bump stops/rear shocks/rear shackles
(all are rusted and tired)
-Front springs/shocks/ upper & lower control arms w/ball joints
What have you found the has a good ride quality(90% street use) and is direct fit. There doesn’t seem to be much offered for our trucks. Any info helps, at this point i am stuck. Thank you
Old Mar 4, 2024 | 12:45 PM
CircusLegacy's Avatar
Hey @MasterOfNone , I'm in the same boat as you were with my RWD 1995 Pickup. Only difference is I live on a dirt road that is regularly deep mud and rutted and potholed. I'm looking to refresh the suspension plus a small 1.5-3" lift. Doesn't look like you got much guidance here. What did you end up doing?
Old Mar 4, 2024 | 01:32 PM
Discombobulated's Avatar
If you go to advanced search and search titles only “2wd lift” you will get a lot of results.
Old Mar 4, 2024 | 04:47 PM
I ended up staying stock hight but sometime wish I had gone higher. Just replaced the shocks is all I have done as far as suspension goes. Oh and the shackles and bushing were shot so got them too.
Old Mar 4, 2024 | 05:56 PM
prcnctoyo's Avatar
Rock Auto https://www.rockauto.com/en/catalog/....4l+l4,1277782
Stengel has leaf springs, etc. https://www.stengelbros.net/INDEX.HTML
Many parts are still available thru Toyota.
FootHilla
Sep 16, 2020 03:04 PM
Aron9000
Jan 9, 2016 12:46 PM
youngbuck
9
Mar 11, 2012 04:55 PM
VonMussa
Apr 3, 2011 10:57 AM
mycotopian
10
Jan 12, 2004 10:30 AM
