Sponsored by: CARiD
Smoke upon startup
Old Jan 13, 2019 | 05:19 PM
gilesitis's Avatar
Smoke upon startup
Upon startup my 1988 3VZE emits white smoke with some blusish gray tint. The smoke isn’t terrible thick but it’s defi enough to notice. It dissapates in 5 minutes or less. It usually happens only when it’s cold outside or it’s been sitting overnight. Also it smells like it’s running rich.
Is this any cause for concern? Like head gaskets going bad?
Coolant is slap full. There is a small amount of oil on one of the valve cover bolts.
Old Jan 15, 2019 | 09:41 AM
old87yota's Avatar
When you say the engine emits smoke on startup, do you mean immediately after the engine starts or within say 30 seconds or so from startup?
If it takes a few seconds for the white smoke to appear, it may just be steam due to low ambient temperatures, which is normal. As the engine and exhaust warms up, the steam will start to be less noticeable. I have the 22R which generates lots of steam when it is cold out and the engine is also cold, which is normal.
Does your exhaust smell sweet?
The bluish smoke could be from old valve guide seals leaking a little oil past the valve stems and when you start the engine, the first several combustion cycles burns the oil that has collected since last startup. This is just my best guess.
Engines do run rich when cold, so that could be what you are smelling. How rich does the exhaust smell? Any soot coming from the exhaust?
Does the oil look normal and at the proper level?
It would be easiest to see the exhaust in person.
Old Jan 15, 2019 | 10:34 AM
Kolton5543's Avatar
Oil smoke on startup usually indicates leaking valve guide seals. 5 minutes seems a bit long though. Usually you'll only see it for the first few seconds.
Old Jan 16, 2019 | 08:46 AM
gilesitis's Avatar
I'll have to go back and look to see how soon it starts coming out. IIRC, it does take a few seconds before it starts puffing.
I wouldn't say the exhaust smells sweet. If anything it smells more like gas. No soot that I can see coming from exhaust. It smells pretty rich upon startup, and maybe gets a little better as I drive it.
Oil looks good to me. I took a pic this morning after firing it up...
taylorham5842
Mar 4, 2012 09:15 PM
2 da max
Dec 27, 2011 08:51 AM
Bobthebuilder
Oct 27, 2007 12:51 PM
KSTacoma
10
Nov 29, 2004 09:09 PM
