Sponsored by: CARiD
Blown head gasket
Old May 12, 2019 | 08:49 PM
4byota's Avatar
Blown head gasket
Hello I have a 96 extra cab t100 3.4 4x4, 304xxx miles and the head gasket went out last night. I have coolant dripping out of my exhaust now, and a good steady stream of white smoke. I need to be able to drop the kids off and get to work, so I help a little help deciding which route to go.
Do I just change out the head gaskets in the driveway or do I get a used motor and put that in there, what do you guy think I should do?
Me and my wiife can work out transportation for a little but I need my truck back asap
Old May 12, 2019 | 09:06 PM
millball's Avatar
I'd go with a used lower mileage engine
. Especially if you could get even as short as a 30 day warrantee on the new engine.
It'd give you a chance of satisfaction.
304 thousand is substantial mileage to do nothing but a gasket job .Fact is, you cannot know for sure that you don't have a cracked head, or heads that require resurfacing or other valve work.
Others might certainly disagree. Just my .02
Old May 30, 2019 | 08:38 PM
4byota's Avatar
I picked up an engine out of a 01 4Runner with a smashed back end and a gasket set to freshen it up a little. I just did the timing belt and water pump on my old engine 6000-9000 miles ago, do you think I could reuse that without issues?
Old Oct 12, 2019 | 02:40 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
What did you end up doing?
Old Oct 12, 2019 | 04:16 PM
4byota's Avatar
Valve cover, intake, and oil pan gasket. And then threw it in and destroyed my transmission in the process. And still don’t have reverse in my new trans
PDX_1ton
Mar 20, 2017 03:37 AM
akmush
Jul 21, 2016 06:39 PM
mattbatson
25
Jun 26, 2015 10:33 AM
cchinny
Sep 21, 2009 12:47 AM
toomster
Feb 12, 2008 10:46 AM
