Sponsored by: CARiD
Mysterious 22r Ignition/fuel issue
Old Oct 18, 2011 | 08:25 AM
abelisv's Avatar
So I have an 88 Toyota Pickup (EFI). The engine (2.4L 4 cyl. 22r) was swapped from a carbourated 87 pickup, and the fuel system was changed back to EFI.
The truck will start and idle. If you apply throttle immediately after starting, the engine floods and stalls. If you're careful with the gas; it will drive, but then will randomly start hiccoughing and then you lose all power; if you mash the gas at this point the engine stalls.
Things I have checked:
Vaccum Hoses
Catalytic converter / exhaust backpressure
My Ideas:
Mass Airflow Sensor?
Fuel filter?
Computer?
Some other ignition issue?
Any help you guys could give me would be much appreciated. I really need to get this beast moving!
Thanks in advance,
-Abel
Old Oct 18, 2011 | 08:38 AM
xxxtreme22r's Avatar
Are you using the EFI distributor/ignitor? What do you have the ignition timing set at?
Old Oct 18, 2011 | 08:45 AM
abelisv's Avatar
Yes I am using the EFI distributer and ignitor. I dont know offhand what the ignition timing is, but I can find out tomorrow
Old Oct 18, 2011 | 08:46 AM
Don't forget to set it with the jumper in the diagnostic connector. Otherwise you might experience this issue as well.
Old Oct 18, 2011 | 08:50 AM
abelisv's Avatar
sorry I dont follow; experience what issue exactly?
Old Oct 18, 2011 | 08:51 AM
the issue your having. It might be something else, but checking timing is easy.
Old Oct 18, 2011 | 08:55 AM
abelisv's Avatar
Alright; I'll check the timing tomorrow and post up again, thanks a lot!
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
RaginAsian91
All Other Toyota Swaps
Aug 23, 2015 10:27 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Odin
Jul 15, 2015 09:28 PM
