Sponsored by: CARiD
Engine knocking
Old Oct 25, 2011 | 08:58 PM
trent89's Avatar
Engine knocking
I got a 1989 toyota pickup 22re 2.4 litre I got a problem with. It Got a knocking sound when I start and it hits 2000 rpm just knocks hard till it gets to 2500. Continues to knock mainly when I push the clutch in to shift. Sounds like it's comin from valves but not to sure. Any help?
Old Oct 26, 2011 | 12:02 PM
trent89's Avatar
Anybody? 22 re knocking from valves
Old Oct 26, 2011 | 12:03 PM
Fink's Avatar
When is the last time you did a full tune-up? What are the last few things you've done on it? Have you tried running a higher octane fuel to see if it gets better?
Fink
Old Oct 26, 2011 | 12:23 PM
xxxtreme22r's Avatar
I had that problem too, 6000 miles later I spun a rod bearing. Originally thought it was a timing chain. Take your valve cover off and inspect the chain guides first. Otherwise that sounds like the symptoms I had and you better start planning for a new engine or rebuild. Valve chatter these are known for doesn't come and go like that.
Old Oct 26, 2011 | 01:47 PM
trent89's Avatar
Haven't had a tune up since I got it a year ago. Kinda what I was lookin into got all the valve gaskets to do a valve check but not a damn clue on what to do. Haven't tried octane fuel yet and really haven't done anything to it. New exaust and Monifold is aboot it
Old Oct 26, 2011 | 01:59 PM
Fink's Avatar
Take xxxtreme's advice - tear it apart and see what's doin'. Replace what you can and just start preparing for the worst.
Fink
Old Oct 26, 2011 | 02:12 PM
trent89's Avatar
I couldn't get a whole new head and valve ˟˟˟˟ worse is worse? Id have to hear the whole thing apart n rebuild?
Old Oct 26, 2011 | 02:17 PM
Rod bearing would be bottom end. If it turns out to be that, your gonna have to replace or rebuild the entire engine. Some people have taken the oil pan off and just replaced the bearings, but I highly recommend against doing that, especially if it's already been knocking.
Take the valve cover off and look at your timing chain guide(s) first mainly the drivers side guide. As it tends to have the same types of symptoms as a rod bearing that is just starting to go bad. It does sound slightly different then a worn out rod bearing but to someone who's not familiar with the many different types of knocks it can sound the same.
This I feel is NOT a valve tick. As a valve tick doesn't just come and go like that. And besides even with a brand new engine, the valve train on these engines are loud to being with.
Old Oct 26, 2011 | 02:25 PM
trent89's Avatar
Thanks man. Real great help I'll let u know how it pans out
Old Oct 26, 2011 | 02:26 PM
trent89's Avatar
If I got a tuneuP would they hook that ecu ˟˟˟˟ up to tell me for sure? U know what they do in a full tune up exactly?
Old Oct 26, 2011 | 02:29 PM
Fink's Avatar
What word do you keep using that is tripping the censor?
I can't think of a single cuss word that would fit these sentences.
Fink
Old Oct 26, 2011 | 02:34 PM
trent89's Avatar
S. H. I. T. Didnt know they bleeped it
Old Oct 26, 2011 | 05:39 PM
trent89's Avatar
[QUOTE=trent89;51809452]If I got a tuneuP would they hook that ecu ˟˟˟˟ up to tell me for sure? U know what they do in a full tune up exactly?
Old Oct 26, 2011 | 06:14 PM
westjohns yota's Avatar
yeah man thats sounds like my truck when i bought it, you can get the bottom end rebuilt for about 350$ but its better just to rebuild the whole motor.
Old Oct 26, 2011 | 08:43 PM
trent89's Avatar
Should I get a tuneup or just go straight for the rebuild?
Old Oct 27, 2011 | 03:51 AM
Ok maybe I should kept the word rebuild out of it at first. Unless this is an engine ping, a tuneup doesn't typically make an engine noise go away. You shouldn't be talking going right to rebuild unless you have taken that valve cover off and see what's going on with the timing chain. It's extremely simple to take off and you shouldn't have to take it to a mechanic to inspect the timing chain guides.
Bad timing chain guide and/or rod bearing isn't gonna show up on an ecu scan either.
A bottom end rebuild is gonna cost you a heck of alot more then $350 if yur gonna have a mechanic do it for ya.
Old Oct 29, 2011 | 04:12 PM
trent89's Avatar
So am I just gunna look and make sure my chains nice and tight? how would I inspect my valves?
Old Nov 2, 2011 | 01:14 AM
Rebel Lady's Avatar
I agree with ^^^^^^^^^ I will check on my truck had bad noise and knock..I ll find out what wrong
Old Nov 2, 2011 | 02:33 PM
gagnier6996's Avatar
Sounds like more than valve train issues to me. You need to get a mechanic to listen to it or post a video up to youtube so people can listen to it.
Old Nov 2, 2011 | 05:50 PM
Rebel Lady's Avatar
I started it and runs rough. Possibly out of timing. I ll check on timing chain possible bad.
