Sponsored by: CARiD
tcase removal
Old Oct 4, 2011 | 09:55 AM
slowngreen's Avatar
tcase removal
I just got my 4.7 gear kit for my single case, wanna remove the tcase by itself and leave the tranny in place...Doable right?
In what "order" should I do things? Would I block the tranny up and then do the bolts on the tcase to tranny then the cross member? Or what?
Is the tcase really heavy too?
Old Oct 4, 2011 | 10:43 AM
waskillywabbit's Avatar
www.ncttora.com/fsm
:wabbit2:
Old Oct 4, 2011 | 11:12 AM
dropzone's Avatar
Fossilized
I use my tranny jack when doing my t/c's
I block the transmission, you can let it down slightly at an angle but IMO don't allow the trans to fully hang as it puts too much strain on the motor mounts.
Old Oct 5, 2011 | 05:56 PM
slowngreen's Avatar
any of you have any trouble removing the 30mm nut on the tcase? The very first thing to do according to the trail gear instructions. Ive not had any luck breaking it loose.
Old Oct 5, 2011 | 06:18 PM
4Crawler's Avatar
Mine was very tight (installed by Marlin when he set up my dual cases). I made up a steel bar to bolt into the edge of the flange that in turn was long enough to contact the frame. Then I slid a 3' long steel pipe over the breaker bar and was just barely able to get the nut to break free. Started with the pipe just under the frame and it bent almost to the ground before the nut broke free.
Old Oct 6, 2011 | 10:57 AM
slowngreen's Avatar
Ok got that off. Now Im stuck on getting the oil pump gear off/over the ball on the shaft...Any tips?
Old Oct 6, 2011 | 11:25 AM
93toyrunner2's Avatar
Originally Posted by waskillywabbit
2x on waskillywabbit's post.
FSM download, step by step instructions.
Old Oct 7, 2011 | 03:20 PM
slowngreen's Avatar
Yeah I downloaded a manual from there but it wasnt really helping. Between it, marlins instructions and Trail gears, I finally figured it out lol. Think its ready to put back in now...
Old Oct 11, 2011 | 01:00 PM
slowngreen's Avatar
Stupid comment prolly but I cant believe how easy that was? Alittle confusing at times but really it is suprising how easy it was. Just put a jack under the tranny then pulled the tcase out, swapped the gears, pushed it back in place and viola. I sure am glad I finally did it, havent had to touch the clutch crawling yet! Thanks for the help guys.
old87yota
Sep 9, 2015 12:39 PM
gp66
Sep 7, 2015 08:29 AM
yourrealdad
Jul 29, 2015 11:08 AM
keithporter83
Jul 24, 2015 07:37 AM
crashburnoveride
Jul 10, 2015 06:39 AM
