Sponsored by: CARiD
1986 XTra Cab swap
Old Sep 25, 2011 | 09:02 PM
bobben's Avatar
1986 XTra Cab swap
I have a rusty (water leaks into cab) 1986 Ext. Cab 4x4 Turbo (Turbo removed), I also have a not rusty 1986 Ext. Cab 2x4 w/22re . Will the cabs swap without mods? I know the fenders won't but will the cabs swap? Both are auto trans.
Old Oct 6, 2011 | 08:55 PM
bobben's Avatar
Is my post in the right place?
I would think there is a reference that would answer this post.
Old Oct 7, 2011 | 12:32 AM
wyoming9's Avatar
Smile
If you are a good fabricator/welder you can do most anything the deciding factor is time and$$$$$$.
I am not sure if the 4x4 and 2wd trucks share the same frame that is where you would need to fabricate new cab mounts and such and steering linkage perhaps.
I have never been under a 2 wd truck so I am not sure
Old Oct 7, 2011 | 04:13 AM
93Xtra-Cab's Avatar
Since the "new" cab is a 2wd, you may have to cut out the floor and weld in a hump to clear the transfer case.
Old Oct 7, 2011 | 08:27 AM
James Woods's Avatar
Best way to get an answer to your question would be to go out and measure and compare the body mounts on both trucks yourself. I would think that everything is the same since they are both the same years.
Old Oct 7, 2011 | 01:10 PM
85TurboRunner's Avatar
It'll bolt right up. You will probably have to do some cutting for the transfer case shifter though.
nanhodges2733
May 29, 2020 03:28 PM
mskalmus
May 28, 2017 07:51 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Steezy96yota
Jul 6, 2015 10:00 AM
