Double Check-what are these in the pics?
if I am looking at that right yes fill and drain, but not for the same thing. one is for transfer one is for transmission. At least for manual trans. Not sure if the autos share the fluid between the two or not.
the one for the steering shaft is called a COUPLING ASSY, FLEXIBLE 45230-35020 1983.08-1988.08 LN5#, RN5#, 7#
there is another part number that's not available 45230-35040 1983.08-1985.08 LN65, RN6#
notice the different frame codes.
So if this Coupling is bad can it be causing me to have a "bump" feeling in my steering, hard to explain it feels like i have to get the steering wheel to turn over a hill then to turn back i have to get it so to speak back over the hill
That coupling is also known as the rag joint. Rubber in the middle absorbs road vibration, then there are two studs that move in slots and when you turn the wheel really hard, the stud hits the side of the slot. If rubber it worn out, you have nothing in between the two slot edges:
Might check that rubber piece and see if it is torn. If so, should be able to get a replacement one from a junkyard. Toyota used the same design from '84-'95 and even similar on the '96 and later Tacomas and 4Runners.
- http://www.4crawler.com/4x4/ForSale/...eringExtension
Does not replace the rag joint, rather extends it:
You might want to shorten your steering shaft a little bit:
- http://www.4crawler.com/4x4/ForSale/...irculatingBall
Looks like yours is extended a little too far, pushing the rag joint into a potato chip shape instead of flat.
so like i said if its worn out and i can move it around side to side and up and down with my hand will it cause be to have wierd steering issues? like getting really hard then easy instead of it just being smooth turning
Thanks 4crawler. Have you ever heard of anybody replacing the rag joint with some type of metal or other stuff. Mine is very close to my headers and when it melts i want to replace it with something else
Or get a shaft from an '83 or earlier pickup, they have a sliding spline joint instead of the rag joint.
I think the shaft is a pretty much direct swap. Not 100% sure, but the splines on the steering boxes should be similar and the length similar. Or put a metal heat shield between the header and the steering box. That will do a lot to cut down the heat, or wrap that section of header in some header insulation.
If it is worn out, will it cause hard steering? I have in and out play in my steering column and it appears to be coming from the coupling. When it is compressed the steering is stiffer than normal and it will not recenter after a turn. When it's not compressed, steering wheel pulled up towards me while driving, steering is normal and re-centers like it should after a turn. Could a worn out rag joint cause the in and out play as well as the hard steering?
I have the same question about the steering coupler / rag joint.
Don't think it'll cause hard steering. It can lead to a lot of slop, like turning the steering wheel 1/2 turn either direction before the wheels turn. Easy to see if that is the cause of the play, have someone sit in the cab and slowly turn the steering wheel back and forth to the point the wheels start to turn and watch where the motion is and is not. That is if the shaft above the rag joint turns back and forth yet the shaft below the rag joint is still, there is your answer. Now if the rag joint is intact and you stretch or compress it into a potato chip shape, that can cause tight then easy steering as you turn the wheel. That stretched piece of runner adds tension to the shaft and loads up the u-joints and you feel the lumpiness in the u-joints due to the tension in the rubber. Might be a bearing up farther on the shaft is binding up when you move the steering wheel/shaft up and down.
The pictures make the coupler look round, but it's really more potato chip shaped when looking at the other side.
Would this amount of play be caused by a bearing? It's so frustrating how perfect it is when it's "up", but how stiff the steering is when it's down on the column.
Probably need to isolate the steering shaft and see where the tightness is coming from. How? Unbolt at the rag joint and see if the steering is still stiff. If yes, then un-clamp the shaft at the firewall and re-test:
If it is still stiff, then it is something between the firewall and the steering wheel. Remove the trim covering the steering column and see if you can isolate the problem. You can also lengthen or shorten the shaft at the above clamp by shoving the splines up farther into the clamp or pulling them out farther. By shortening the shaft, you may be able to achieve the same effect as you feel by pulling it up.
