Sponsored by: CARiD
installing electric fan need help with wiring
Old Dec 27, 2010 | 10:26 PM
pjb00stin's Avatar
hey,
i picked up an electric fan from the junkyard,and the harness has 4 wires coming from it.
black
green
2x green w/ stripe
i tried the fan out by conenecting it straight to my battery.the two green w/ strtipe wires seem to be the power wires.the other green wire,when i connected it to [+] did nothing. Do i just cut off the end of that wire and seal it? And since both green w/ striped wires work,do i connect both of them to my controller,or just one wire,and seal the other wire?thank you
pj
Old Dec 28, 2010 | 12:34 AM
wyoming9's Avatar
Red face
As you will just make sure the fan is moving the air the way you want.
was it mounted behind or in front of the radiator.
It would be not good if it was not pushing air in the correct direction
Old Dec 28, 2010 | 04:45 AM
waskillywabbit's Avatar
I got 3 cups here. Which one is the red ball under?
You need to do a lot more homework for this mod if you want it to actually cool your Toyota. Several good electric fan swap threads. Seafairinman and bamachem are just two.
Search.
:wabbit2:
Old Dec 28, 2010 | 05:02 AM
runnermedic's Avatar
check my post
mercury villager electric fan swap
MO transplant
Apr 23, 2023 11:58 AM
sandyota
Feb 4, 2021 11:16 AM
coryc85
Sep 9, 2015 06:24 AM
bryan34w
Jul 6, 2015 05:53 PM
zd92655
Jul 5, 2015 04:25 PM
