Sponsored by: CARiD
Seafoaming a 3vze?
Old Jan 8, 2011 | 05:56 PM
noble's Avatar
Seafoaming a 3vze?
Hey,
New to working on the 3vze... From what I've read there will be plenty of work to be done on that d@mn engine...
So... Is there an easy way to seafoam the 3vze? I haven't dove into it yet, but apparently the PCV valve is a total PITA to even get too... And that is what is suggested when you throw Seafoam in to clean up carbon and varnish.
Any suggestions are most welcome
And if anyone has a picture of where the brake booster hose is on this engine that would be awesome (it was suggested elsewhere)
Old Jan 8, 2011 | 06:01 PM
85gijunk4x4's Avatar
im not fimilair with 3vz's but im guessing you can put seafom into the brake booster vacuum line. thats one of the common vaccum lines on all engines that people use.
ill just let others confirm this, or post up and easier/more effecient way because im not familiar with the engine, but i hope i helped
Old Jan 8, 2011 | 06:12 PM
Uthro69's Avatar
Here is a pic of a brake booster line
stick that hose into the sea foam dont totally submerge it stick it in and rev the engine a bit till it starts sucking seafoam in, get a cycle going till you have about half the bottle if not all of it, then shut the engine off let it sit for a few hours come out start it up and put on a gas mask it will smoke alot depending on how nasty the engine was.
Old Jan 8, 2011 | 06:14 PM
noble's Avatar
Perfect... Thank you so much that helps a lot... I can use that line to feed the engine seafoam?
Old Jan 8, 2011 | 06:15 PM
Uthro69's Avatar
i added some stuff, thats how ive done it in the past. or jsut thru the carburetor, id wait for a few more posts just incase im mistaken
HAs happened in the past
Old Jan 8, 2011 | 06:28 PM
93yotaSR5's Avatar
heres mine.
i used a hose that goes into the side of the upper plenum. popped it off, and poured it in. follow the directions for using the vac line.
ive sea foamed it twice, and once through the fuel tank.
runs like a charm now!!!! oh yeah, and ive ran it through the engine crankcase to clean it up as well. it came out pretty black when i changed the oil.
http://www.youtube.com/watch?v=fzQ8DHzaNII
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
