Sponsored by: CARiD
Breaking the lock on my cam bolt
Old Dec 5, 2010 | 12:23 PM
snickell's Avatar
Howdy, I'm trying to get my cam bolt off to do an H/G replacement. Can't seem to get it, but a big part of that is keeping the cam from turning. I've tried wrapping some steel wires around it (broke a few wrapped together), but I'm worried about hurting the chain/cam. I've sprayed some Pb blaster on, we'll see what happens.
What's the proper way to "lock" the cam to remove the cam bolt? Or, what's the proper way that doesn't require an SST ;-)
Old Dec 5, 2010 | 12:31 PM
richf's Avatar
When I did my timing chain I just left the truck in gear and the parking brake on and it came off easy.
Old Dec 5, 2010 | 12:34 PM
dubbsbetty's Avatar
Bout' the only way your gonna break those bolts lose (assuming it's the 3.0) is with an impact wrench, unless u have a an sst or can fab one up yourself. I did that job a year ago on my 95' and had to stop there because of the cams. Others have had good luck with jamming some sort of wedge between the gears and the block but i didn't like that very much. I would be most concerned with damaging the teeth on there. The impact takes em' right off, hope that helps
Old Dec 5, 2010 | 12:43 PM
snickell's Avatar
I'm considering locking the cam by putting a wrench on the crankshaft bolt and letting it lock against the frame. I'm worried about stretching/harming the chain though... is that a real concern?
Old Dec 5, 2010 | 12:49 PM
snickell's Avatar
Yeah, I figure that's equivalent to my idea of locking the crankshaft using a wrench on the crankbolt jammed against the frame (I've got an automatic, alas, so I probably can't get the truck into gear at this point). I'm still worried about applying that much force to the timing chain, reckon it wouldn't break but really don't want it stretched.
This is a 22re btw.
-Seth
bigjstang
Jun 2, 2025 03:56 PM
okamikai
Apr 30, 2018 10:19 PM
thefishguy77
Jul 30, 2015 10:59 AM
pyramid
Jul 30, 2015 10:05 AM
yourrealdad
Jul 21, 2015 11:13 AM
