Sponsored by: CARiD
Fault Code 12
Old Jan 3, 2011 | 03:13 PM
gbftats's Avatar
Fault Code 12
My 87' 22re has the check engine light and is giving me code 12. I found a thread that gave me this info:
(code 12)RPM Signal No G or NE signal present for 2 seconds during cranking
Open G circuit
Open, short in G or NE circuit.
Distributor
ECU
I have replaced the Distributor and ECU.. I dont know what the "12 RPM Signal No G or NE signal present for 2 seconds during cranking Open G circuit Open, short in G or NE circuit" are.
Please help, im going nuts trying to figure this out.
Old Jan 3, 2011 | 03:39 PM
4Crawler's Avatar
Does the code come back? If not, it may have been a one time thing. Might have been somebody pull started it or hot wired right to the starter to fire it up once.
FSM should have some detailed troubleshooting steps for the code.
Old Jan 4, 2011 | 08:33 AM
gbftats's Avatar
Yes it comes back. I pulled all the fuses just to make sure it was'nt stuck in some sort of memory. Still code 12.
Old Jan 4, 2011 | 09:02 AM
gbftats's Avatar
From what i gather it is the knock sensor. I did not realize it had one. There's a sensor in place, but it is not wired.. Does anyone have a wiring diagram?
Old Jan 4, 2011 | 12:48 PM
4Crawler's Avatar
Should be about 10:00 o'clock from the oil filter, yellow sensor with a round yellow plug and single wire connector:
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
