1999 TACOMA w poor mpg
I just bought a 1999 tacoma, xtra cab, 6cyl, automatic with 187,000 miles and 31" tires. It seems to idle and run fine but a little short on power maybe, the problem is Im getting 8 or 9 mpg and have no idea what the prob can be, any ideas?
I would start at the typical maintenance items if you don't know what the previous owner did or didn't do.
1. Check your air filter.
2. Oil change
3. Spark plugs - NGK or Denso only
4. Spark plug wires- NGK or denso
5. Make sure the tires are aired up to 32psi
6. Look and see if there is a sticker on the radiator or the front cover stating if the timing belt has been changed.
7. Time to buy a Haynes manual
2. Oil change
A little short on horsepower compared to what??
Yes I must say my 3.4 is short on horsepower compared to a friends 400 plus horsepower Duramax diesel in his 3/4 ton pick up.
How much weight do you carry around in the truck?
What gears are in the truck??
What rpm do you see at 60mph ??
What kind of driving do you do city or a 100 mile high speed trip to work??
Are you in the mountains or flat lands
What kind of temperatures?
How much idle time??
All these things factor into the mileage you get.
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
Dec 29, 2015 12:44 PM
