Sponsored by: CARiD
93 pickup hvac backlight question
Old Dec 27, 2010 | 07:39 PM
btoppen's Avatar
I just got a 93 pickup, base model, and there is no "backlight" behind the heat/air/fan controls when the lights are turned on, I was wondering if there is supposed to be one, or, since this truck is as bare bones as you can get, did Toyota figure that seeing where your fan/heat/vents were at night was a luxury? I tried the brightness reostate, and several slaps to the general area, but no luck. If there is a bulb back there, anyone got a good link to pulling that area apart without damaging 17 year old plastic?
Old Dec 27, 2010 | 07:52 PM
myyota's Avatar
There is a light in the heater control assemble, the problem is, that you have to take the dash a part to get to the light.
Old Dec 28, 2010 | 10:13 AM
vincepower's Avatar
The is a little light bulb with a green rubber thing on it. You do have to dissemble the entire dash to get to it though unless you can some how pry the display plastic off off the ac knob area without breaking it.
Old Dec 28, 2010 | 01:49 PM
vincepower's Avatar
Hey man heres the factory service manual for your truck. The Body Mechanical section has the whole dash lay out.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Dec 28, 2010 | 07:42 PM
MountainTree's Avatar
you actually can just pry the face off to get to it, i did mine just the other day. there are instructions in the repair section on this site on how to do it. all you do is pry the face off and pop out the clear plastic piece behind it and the bulb is right there. it only took me about 20 minutes to change.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
cyclist231
Jul 7, 2015 12:56 PM
