Sponsored by: CARiD
removing crank pulley
Old Dec 24, 2010 | 08:55 AM
Frumundajs7's Avatar
Is there any way of removing a crank pulley from a 22re that is on an engine stand with no flywheel. Any way other than an impact gun?
Old Dec 24, 2010 | 09:01 AM
justin_4runner's Avatar
put the bolts in on the flywheel side, and use a bar to hold it aginst one of the arms that are holding the motor, then use a breaker bar to get the bolt free, and lots or wd-40 or pb blaster to free the rust...
Old Dec 24, 2010 | 09:04 AM
Philbert's Avatar
Put it back in the truck and try the bump method with the starter.
Sorry, couldn't resist
Good luck
Old Dec 24, 2010 | 09:06 AM
do u have the pan off? if so u can also put bar in there to lock up the motor and break it free that way..
Old Dec 24, 2010 | 09:11 AM
James Woods's Avatar
http://www.harborfreight.com/20-inch...nch-97073.html
use an old rubber hose and wrap it around the pulley, than install above tool and hold with ratchet or breaker bar and loosen bolt.
Old Dec 24, 2010 | 09:25 AM
I can take the pan off and do this but I am not too sure it is a great idea. I think i am going to bite the bullet here and order a nice impact gun and just start the dis-assembly of the top end now.
Old Dec 25, 2010 | 06:52 PM
Okay, so I used 2 different impact guns with no luck... I resorted to putting a 15mm deep impact socket wedged between the rod cap and the side of the block. With a 1/2in breaker bar and 2 jack handles attached to it for leverage we finally got it to break free.It is amazing what 15+ years of life can do to a bolt!
Old Dec 25, 2010 | 06:59 PM
aa1911's Avatar
too easy, have a shop do your timing belt and not torque the CS bolt! the CS pulley will FALL OFF within the year, ask me how I know!!
Old Dec 25, 2010 | 10:14 PM
Operationpurplepower's Avatar
I've put 2x4 in between crank n block to get 1 out b4 tried all the methods above none worked for me . Thing was on there. Used the wood and about a 4foot 3/4 inch ratchet. Never had such a problem with one b4
Old Dec 25, 2010 | 10:29 PM
LOL at this.. i will be doing all of my own work!
Blamalam
Mar 12, 2022 07:34 AM
TJWilly
Jul 31, 2015 02:05 PM
yoterr
Jul 24, 2015 04:29 AM
redneck17
Jul 17, 2015 07:44 PM
dinks07
Jul 15, 2015 05:34 PM
