Sponsored by: CARiD
How to identify LSD?
Old Dec 15, 2010 | 06:55 AM
moroza's Avatar
We're going to go look at an 85 4WD. Is there a way to tell if it has an LSD, short of actually lifting the rear and spinning the wheels?
Old Dec 15, 2010 | 07:14 AM
Swimmerboy2112's Avatar
Easy, they are all open diffs. (correct me if i'm wrong).
Old Dec 15, 2010 | 08:25 AM
Outsane's Avatar
take it around a tight corner and see if the rear wheels chirp..
Old Dec 15, 2010 | 08:29 AM
snobdds's Avatar
Well yes, they are all open diffs from the factory, but who's not to say they added one after the fact? I think he is saying they are claiming there is an LSD in there and they want to confirm it.
Yep, like stated above, make a tight turn and see if it binds up.
Old Dec 15, 2010 | 09:18 AM
AxleIke's Avatar
Well, mine never chirped ever. An LSD is not a locker. It won't chirp the tires.
Best way to test is to find some gravel, and try burning out. Better is to do it in low range on a dirt pile. If both rear wheels start spinning, you have an LSD, if only one spins, you have an open diff.
Old Dec 15, 2010 | 09:21 AM
Outsane's Avatar
put some water on the road and do a burn-out.. and count the skid marks
Old Dec 15, 2010 | 09:51 AM
ah okay, sorry for the misunderstanding.
Old Dec 15, 2010 | 10:35 AM
91diesel's Avatar
my V6 4/gear rear end would usually spin both tires on gravel and it was an open diff....
Old Dec 15, 2010 | 11:37 AM
clydehatchet's Avatar
mid 80's had an LSD as an option for a short while. it was somewhat of a promotional deal from toyota. friend of mine has an 87 with an LSD. he bought the truck off the show room floor. it was very a uncommon package, but i think is was on the SR5. anyway, my point is that it could have an LSD from the factory, but very unlikely.
Old Dec 15, 2010 | 12:21 PM
AxleIke's Avatar
Which is why I suggested driving up a dirt mound. As the tires dig in, only one will spin if the diff is open.
Old Dec 16, 2010 | 04:16 PM
Sleepr71's Avatar
I've got an '85 SR5 Xtra-cab 22RE-Efi that's stock as a rock but spins both rear tires...forward or backwards!! Don't know the axle code,but judging by how it acts..I'd say it has a factory LSD of some sort...or somethings about to break!
Old Dec 16, 2010 | 04:19 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
This. LSD is NOT equal to a locker.
From the factory, 99.999% Toyota's are open diffs. And yes, who's to say somebody hasn't bought into the scam of a TRD or Aurburn ltd. slip and put one in it.
If you want a dang good LIMITED SLIP, you get a True Trac or Torsen.
To test. Jack one wheel up and spin it around with the tranny in neutral.
The wheel on the ground is acting like the one that needs power. And the one spinning is the one that actuates the springs and clutches (or gears if you're lucky) to do it.
The G80 is the POS "Gov Lock", but you get the point with the "limited slip"
http://www.youtube.com/watch?v=p8nAbg5suFw
http://www.youtube.com/watch?v=rGlacQlBGcQ
Old Dec 16, 2010 | 05:11 PM
muddpigg's Avatar
A factory locker was the Torsion LSD unit, well was stock in the Supras. Some installed them into our trucks. The solid axle I SAS'd had one in it. To my knowledge wasn't stock in our trucks.
Old Dec 18, 2010 | 04:46 PM
There were 2 ltd slips, NOT lockers, in Supra's.
1 was a spring and plate type in the 7.5" rear early Supra's.
And the other was an 8" Torsen in the later 1-2jZ type Supra's.
Try to be less confusing with, "A factory locker was the Torsion LSD unit" next time...
Old Dec 18, 2010 | 04:58 PM
muddpigg's Avatar
Only took you 2 days to search, your so much more accurate when you search instead of just running your fingers.
I stand corrected thought listing LSD was clear.
Old Dec 18, 2010 | 05:07 PM
I knew about the 7.5" already, but I'm not a fan of those ltd. slips...
They are HIGHLY economical tho...
The 8" Supra/Torsen I didn't know, or even know what 8" diff they bolted into. I have searched E-Bay though and found them too expensive, so that option was out.
If you've put on in a Hilux, I'd love to know what diff specifically they (the 8") bolt into...
The V6/Turbo or the 4cyl? Or both?
And PS. Don't blame me TRD listed a clutch plate and spring type LSD in their parts catalog...
So there is a "TRD" limited slip...
http://www.drivetrain.com/parts_cata...ited_slip.html
Old Dec 18, 2010 | 05:22 PM
muddpigg's Avatar
When I bought the front axle for my SAS to my suprise when a started taken axle apart there was a Torsen unit in it. I can't remember if I posted pics here on YT or just email Zuk, cause I had no idea what it was. I sold it for almost what I paid for the axle. Which was a fair price to the buyer. I got a pretty good deal on front axle. Brakes were rusted up so couldn't spin then to check open dif.
I think the Torsen is a superior unit to the clutch type LSDs. It also does a better job of splitting the torque to the tires the minimum is like 20% all gear driven. No additives to put in oil either.
Old Dec 18, 2010 | 05:39 PM
muddpigg's Avatar
I got some pics just can't find them.
justdifferentials
14
Jun 11, 2017 08:36 PM
Corvoid
Oct 13, 2015 08:55 AM
JUICE222
Oct 13, 2015 08:50 AM
Bill854x4
Sep 20, 2015 04:32 PM
justdifferentials
Sep 5, 2015 06:52 PM
