Sponsored by: CARiD
I need Advice on gears
Old Dec 29, 2010 | 03:48 AM
traxxi2003's Avatar
Hello everyone!
I own a 1997 Runner SR5 2WD. I will be installing 33x12.5x15. I need advice on what gears should I get to compansate for the larger tires. I would like to at least maintain factory performance as a minimum, but I rather like to have a little bit more power since I use the truck for towing a boat. So, should I go with 4.88 or 4.56 gears? I have looked at the gearing charts (http://www.4lo.com/calc/geartable.htm) and according to the chart the RPM range indicated for 33" tires using 4.88 gears =3230RPMs That to me is to high. considering that with 29" tires I'm running at 2050RPM while doing 65MPH. I'm no expert, that is why I'm asking for help. Thanks!
Old Dec 29, 2010 | 05:53 AM
crolison's Avatar
4.88, you said you wanted to tow
Old Dec 29, 2010 | 06:16 AM
xxxtreme22r's Avatar
"These calculations are assuming a manual transmission with a 1:1 ratio."
I don't believe your transmission is 1:1 in 4th gear.
assuming yours is an auto and an A340E
Ratios 1st: 2.804 , 2nd:1.531 , 3rd:1 , 4th:0.705
the rpm's on that chart would pretty much reflect your RPM's in 3rd gear not 4th.
Old Dec 29, 2010 | 07:49 AM
Mauzer's Avatar
^^ This... and use the SEARCH button, this topic has been discussed a million times!
Old Dec 29, 2010 | 09:11 AM
brian2sun's Avatar
Get the 4.88s.
icentropy
Sep 16, 2020 02:47 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Iceman4193
Jul 15, 2015 04:48 PM
