Sponsored by: CARiD
belt/pulley tensioner bolt question
Old Jan 9, 2011 | 04:25 PM
85gijunk4x4's Avatar
ran into a problem today, 85 22re. im trying to remove my belt, but what i beleive is the tensioner bolt, is just backing out and not releasing any tension on the belt. do i take the bolt completly, or even further out?
Old Jan 9, 2011 | 04:27 PM
xxxtreme22r's Avatar
the pulley is probably not moving/sliding inside the bracket like it's supposed to. I had that problem on mine when I did the manual to power steering swap onto mine.
On the back of that pulley you will see a square or similar shaped block that that bolt threads to.
Come to think of it, I don't remember my bolt threading out that far either, the head should stay somewhat close to the bracket.
oops forgot to mention how I fixed it. Can you say BFH?
Old Jan 9, 2011 | 04:28 PM
92 TOY's Avatar
no....give the pulley a bit of "encouragement"
Old Jan 9, 2011 | 04:30 PM
so i guess ive got a problem lol...
i even tried putting a socket over the bolt and hitting it with a hammer to try and break it loose. idk if i should try hitting it harder, because i dont want to break anything ya know
haha see last edited comment of mine.
Old Jan 9, 2011 | 04:31 PM
wait whats bfh??
I can't say on here it will get me Banned. haha
Old Jan 9, 2011 | 04:38 PM
i guess by encouragement, you mean beat on it alittle bit...
and not to get off topic, but 92 toy, ive been readin up on your headgasket/timing chain thread. lots of good knowledge in there
Old Jan 9, 2011 | 04:40 PM
haha, i looked bfh up on google...theres a few meanings you cant say on here
Old Jan 9, 2011 | 04:41 PM
92 TOY's Avatar
thanks....
and it's a BIG Hammer
Old Jan 9, 2011 | 04:46 PM
ohahaha, i see what ya mean...
thanks alot guys, ill let you know how i make out...
would it be okay to just hit the pulley itself...i dont wanna bend it and throw it outta balance.
Old Jan 9, 2011 | 04:47 PM
aquaprice's Avatar
I'd take the nut off the pulley before banging on it.
Old Jan 9, 2011 | 04:48 PM
it should only need slight taps on the pulley. I wouldn't hit the bolt though cus you might actually damage the threads on it even though your hitting the head. If you can get something in there to pry it that would work too.
Old Jan 9, 2011 | 04:49 PM
if you take the nut off the pulley the pulley will fall off the tensioner if you hit it. Unless you mean thread the bolt all the way out. But then again, that will solve the tight belt issue. hahaha.
another thing to try is to loosen up the alternator bolts and pry that back and use the belt as your leverage on the pulley, if that makes sense. Kinda like how you would tighten the alternator if you didn't have power steering.
wait a minute scratch that. that won't work it's a different belt. doh!!!!! I've been on here too long today haha. That's got to one of the stupider things I have said on here. ROFL.
Old Jan 9, 2011 | 04:50 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
^^^THIS!
The pulley's are clamped on... You tighten the adjuster down 1st, then tighten the jam bolt on the outside of the pulley.
To disassemble, do it in reverse order.
Old Jan 9, 2011 | 04:51 PM
10-4. ill try taking off the pulley bolt, if that doesnt release it, ill put it on a few turns and give the pulley a tap. haha, i dont want a pulley flying at me at mach speed!!
Old Jan 9, 2011 | 04:55 PM
Yeah, the pulley's are a new thing if you're not used to them.
It's common for someone to break the adjuster bolt trying to loosen a pulley b/c you stare at it going "WTF?" not having any idea the forces it holds.
It looks like it hold the pulley on, not adjusts it
That, and dirt and grime can cause it to bind, hence the "hit it" posts.
While that is true, you better make sure the jam bolt is loose 1st... Or you can bend the adjuster bolt.
Originally Posted by tried4x2signN
^^^THIS!
you mean to tell me this whole time I have had my power steering on I was supposed to tighten down on that bolt?
I guess I skipped the power steering section in my FSM.
Old Jan 9, 2011 | 04:58 PM
...im confused...
the jam nut is???
and the tension bolt is??
whey couldnt toyota just use a tensioner pulley like everyone else??? LOL
Old Jan 9, 2011 | 05:00 PM
Jam nut is in the center of the pulley, the tension bolt is the one that you have cracked nearly all the way out.
That's if I am not being stupid again and mis read tried's post.
I guess I got something to check on my truck tomorrow haha. Surprised my pulley isn't making noises because it's "loose"
