Sponsored by: CARiD
fuel tank
Old Nov 26, 2013 | 08:30 AM
redneck17's Avatar
fuel tank
Can you put a bigger tank in a 94 4x4 toyo
Old Nov 26, 2013 | 08:56 AM
83's Avatar
83
Anything can be done.
If you're asking whether a larger tank would bolt right in without modifications, that's another story.
Old Nov 26, 2013 | 04:30 PM
cobolt23's Avatar
To answer it easy, yes. and with no modifcation. From the mounting flange up is the same size on all 4 sizes. 13, 16/17, and 19 gallons.
The size diffrance is made up below. The 13 and 16/17 gallon use one size skidplate, the 19 has its own.
As it is lower, the 19 gallon will loose you about 2-3 inches of ground clearance.
Old Nov 26, 2013 | 04:35 PM
redneck17's Avatar
Thanks went back with new 17 gal
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
mussy01
Dec 13, 2016 08:20 PM
pyramid
Jul 30, 2015 10:05 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
