Sponsored by: CARiD
running w/o a thermostat
Old Sep 16, 2013 | 05:02 PM
robwise's Avatar
My 89 project was having an overheating problem so I removed the thermostat to trouble shoot. The thermostat opened slowly around 190f when I boiled it, but just for giggles I ran the engine without it to see if I could get it to overheat again. And I couldn't. I let it idle in my driveway for awhile (p.s. its over 100 degrees outside here) nothing. drove it around my neighborhood, still nothing. never got over 1/2 on the gauge.
Im going to pick up a new t-stat anyways but I'm curious, what happens when it runs w/o it? I've read everything from "nothing" to "your heater wont work" and "your engine will over heat".
My heater works fine, no overheating either. Anyone have any toyota specific experience with this???
Note: I'm running the 5vz if that makes any difference.
-Thanks
Old Sep 16, 2013 | 05:19 PM
rokblok's Avatar
The main concern is getting the engine to the proper operating temp for efficiency and emissions purposes. Without t-stat it may not get fully warmed up in cooler temps so your mileage may suffer a little. I notice you're in AZ, so depending on where in AZ, it could be 190* ambient....
And if you don't have emissions, then that's one less thing to consider....
Old Sep 17, 2013 | 07:32 PM
Nebo's Avatar
You can but the heater may not work very well
Old Sep 17, 2013 | 07:37 PM
Kiroshu's Avatar
-Increased internal engine wear due to excessive cold operation.
-Poor fuel economy.
-Poor Emissions control.(Check Engine MIL may illuminate).
-Poor Engine performance.
-Poor Heater/climate control performance.
Other than that your good.
Old Sep 18, 2013 | 06:19 AM
PlainJaneYota's Avatar
-Poor fuel economy.
I read the op and was like
What he said...
Old Sep 21, 2013 | 11:16 AM
osv's Avatar
osv
water circulating at full unrestricted speed(no thermostat) through the engine will not sink heat from the metal as well, which is why it looks like it's not overheating.
an open thermostat slows down the water flow, which gives the water time to absorb the heat.
no thermostat means that the engine is hotter, but the coolant is colder, so the ecu is adjusting the fuel and timing based on a colder engine.
Old Sep 21, 2013 | 02:19 PM
84dreamyoda's Avatar
When I bought a rebuilt 22r from a long standing and reputable Toyota rebuilder he gives a 3 year warranty and the only requirement he places is that you use a OEM Toyota thermostat. I'm guessing he knows something.
Old Sep 21, 2013 | 04:27 PM
RAD4Runner's Avatar
Somewhere (4Crawler's site?) there was a mention of Toyota fail-safe/dual control thermostat used because:
When heater is suddenly switched on while truck is already in operating temp, when coolant returning from heater core (cooler than temp at which thermostat opens) hits T-Stat, T-stat thinks coolant is still cold so it shuts off cutting off circulation of the rest of the coolant that's actually already in operating condition (190°?)
My truck's head gasket ( I hope not the head itself) is shut so considering to get that dual-T-Stat after HG is replaced.
Old Sep 21, 2013 | 05:00 PM
robwise's Avatar
that makes sense, good to know.
thanks!
Old Sep 23, 2013 | 08:12 PM
clayton707's Avatar
yea what everyone is saying is pretty much right. a/c isn't gonna work right, the fuel injection isn't going to be optimized along with a whole slough of other stuff. just replace it. it not to expensive.
Old Sep 26, 2013 | 09:59 AM
robwise's Avatar
Yeah like I said, I had no intent of driving around without it, it's too easy to replace (and I'm sure the engineers at Toyota knew what they were doing when they put one in). Just wanted a better understanding of what it did because it seemed like there was a lot of misinformation floating around online.
Old Oct 6, 2013 | 12:44 PM
Rich L.'s Avatar
Some of the guys at the racetrack do this, running the car flat-out most of the time keeps it at operating temps. But if you're on the highway part-throttle, the engine won't be happy staying too cold.
Rich
Old Oct 14, 2013 | 05:16 AM
2010nctaco's Avatar
I agree with what everyone else is saying, with the cost of a thermostat being so cheap, why would you risk it?
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Poncho0206
Jul 10, 2015 06:21 PM
