Sponsored by: CARiD
Mystery Stall?
Old Nov 10, 2013 | 01:25 AM
Gatorbob's Avatar
Mystery Stall?
Brand spanking new new guy here. I own 3 Toyota's. 1986 Toyota Sunrader RV . Basically just a 1986 pick up truck. R22-E Calif. Runs Great. Problem is twice I've been cruising along then out of nowhere it just stalls. Totally random. Won't re start for about 20-30 mins.
Old Nov 10, 2013 | 03:32 PM
slow-mo's Avatar
Does the engine sputter and then die, or does the engine die like a switch being turned off?
Old Nov 10, 2013 | 04:23 PM
theerroneouspenguin's Avatar
Ignition coil maybe? I know on other cars if it gets hot,it stops working and will not work again until it cools down.
Old Nov 11, 2013 | 01:43 AM
Gatorbob's Avatar
I just replaced the ignition coil. And yes, it would just quit and not sputter out. I've not driven it enough to have the problem since replacing the ignition coil. The problem is so random, you never know where or when it's going to happen. That's why it's a mystery.
Currently, I'm replacing small, easy to do, inexpensive parts like the coil, fuel relay switch and EFI resistor.
Bourbonblues
Dec 15, 2017 05:43 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
4runnerstalls
Sep 17, 2015 10:10 AM
