Sponsored by: CARiD
22re overheating
Old Oct 29, 2013 | 04:49 PM
claybrook's Avatar
22re overheating
My 88 toyota usually stays pretty close to the cold side on the temp gauge but the other morning it overheated on me on the way to work 10 minutes down the road. ive replaced the thermostat and gave it hell for 20 mins and it was fine. then next morning it overheated again and does not have any heat. which makes me think it may be the waterpump but i dont wanna replaceif its not the problem. Any ideas??
Old Oct 29, 2013 | 04:51 PM
HighLux's Avatar
3.0? in the truck?
Old Oct 29, 2013 | 04:56 PM
claybrook's Avatar
Its got the 22re in it
Old Oct 29, 2013 | 05:00 PM
HighLux's Avatar
losing water?
exhaust blowing white smoke? smell like antifreeze?
oil/water mixed? you will know trust me by seeing it.
Are both top and bottom radiator hoses warm when truck is warm?
also...with radiator cap off and running...rev it a little...does antifreeze squirt out hole?
Old Oct 29, 2013 | 05:06 PM
claybrook's Avatar
Originally Posted by HighLux
losing water?
It did blow some smoke out after it got warm but wasn't overheating. Then had the cap off today and didn't start coming out or overheating
Old Oct 29, 2013 | 05:13 PM
HighLux's Avatar
IS it losing coolant....have you had to top it off alot lately? or even just once recently?
Old Oct 29, 2013 | 05:29 PM
claybrook's Avatar
Had to top it off yesterday. Now Im thinkin its the head or head gasket
Old Oct 29, 2013 | 05:32 PM
HighLux's Avatar
I was trying to walk you down that path gently. Its super frustrating to have happen. Have faith. they are really good motors usually.
Time for a compression test.
Did you rev it a little with the cap off? not just idling?
Old Oct 29, 2013 | 05:35 PM
claybrook's Avatar
Both never did blow out
Old Oct 29, 2013 | 06:22 PM
rokblok's Avatar
Did it overheat driving down the highway or sitting and idling?
Could be fan clutch not engaging. Or radiator clogged.
If it doesn't have heat, that's either a heater valve or flow issue. I wouldn't condemn head/gasket yet.
Old Oct 29, 2013 | 06:29 PM
HighLux's Avatar
yeah..definatley need to do some more elimination type stuff. Not like its a 3.0 or something. The 22re wants to live!!
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Logz808
Jul 26, 2015 07:09 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
