Sponsored by: CARiD
power steering help
Old Nov 2, 2013 | 04:16 AM
lilrobo's Avatar
power steering help
hey guys
i installed a power steering box from a 79-84 toy ,, into my 53 f100 with a chevy 350 , the first time i had a bad wining or hissing , i did try to get all the air out also , so i change the pump again and it seems fine when cold then it comes back ,, i dont believe its the pump , could be but is there anything i can check with gear box ???, i did buy it here from a guy used ,, so i dont much about it
thanks please input
Old Nov 2, 2013 | 04:44 AM
rokblok's Avatar
Make sure you're using ATF in power steering. Power steering fluid doesn't do well.
And you mentioned you did a box, then you mentioned you replaced the PUMP again.
Box is what moves steering linkage, pump is what assist the box. Or did you do it all?
Old Nov 2, 2013 | 05:47 AM
lilrobo's Avatar
i started off witha GM pump for my chevy 350 and it done the same thing as now ,, so i replaced the pump thinking i got a bad pump ,, i am using the same gear box from the start ,, now if i hooked the lines up wrong would it work ??,, i can change the fluid and use AFT ,, i would have thought it would steer easier than what it does ,, but i can live with that
thanks
Old Nov 4, 2013 | 07:58 AM
lilrobo's Avatar
could it be the fluid is getting hot ,, should i use AFT ??
Old Nov 4, 2013 | 08:07 AM
theerroneouspenguin's Avatar
Should we use atf in the PS pumps?
Old Nov 4, 2013 | 08:14 AM
lilrobo's Avatar
people has told me that AFT is a lot better to use ,, i dont know seems like my problem happens after it get hot
thanks
Old Nov 4, 2013 | 08:17 AM
I know the PS goes in these. And I think the rack goes after that. IFK.
Old Nov 4, 2013 | 08:20 AM
lilrobo's Avatar
i got something going on seems like when it cold its fine,, after it warms up or gets hot ,, i start to here noises,,, wining hissing or something like that
thakns
Old Nov 4, 2013 | 08:32 AM
Whining is the pump going out or not having any fluid. Checked all hoses and ˟˟˟˟ for leaks? I've heard these pumps are crap to be honest.
Old Nov 4, 2013 | 08:36 AM
lilrobo's Avatar
this the second pump i installed ,, it is full of fluid and i dont see any leaks the gear box was used it came off a 82 yota i think ,, could it be that they require more pressure than the pump it putting out ?? its a GM pump 20-6800f from cardone
thanks
Old Nov 4, 2013 | 08:37 AM
I honestly have no idea. I know there is some sort of pressure you must be wary of but I don't know exactly.
Old Nov 4, 2013 | 02:33 PM
lilrobo's Avatar
does Toyota's use AFT
Old Nov 4, 2013 | 02:37 PM
I would. Everything I've read about them has pointed to yes. The regular fluid can't cope with it. So they use atf.
Old Nov 8, 2013 | 02:29 AM
lilrobo's Avatar
well i drained the PS fluid for a day or so ( just busy ) i jacked it up and turned the wheel ( motor not running ) and more fluid cam out ,, then i refilled it with ATF it seems to be better ,, it made a noise at first but went away ,,, i ran it and turned the wheel several times to right and left ,, saw a lot of air come out ,, the true test will come this evening when i drive it ,,, i'll you know
thanks guys
Old Nov 8, 2013 | 09:28 AM
thanks guys
How did you drain it? Let us know cause I'm curious as well.
Old Nov 8, 2013 | 01:31 PM
lilrobo's Avatar
i unhooked the low pressure line and let it drain for a day and the i turned the wheel several times and more cane out ,,
Old Nov 8, 2013 | 02:19 PM
Wish I had a day to let it drain. Lol. Its got a leak so I'll just let mine run out and whine. Lol
Old Nov 8, 2013 | 08:21 PM
RSR's Avatar
RSR
Toyota does use ATF, at least on my 93... Head over to Amsoil, and enter your truck info and they'll give you all your factory fluid/grease specs.
You should be fine using the standard flush procedure to switch fluids. Empty reservoir w/ baster. Remove low pressure return line. Drop into bucket. Cap reservoir return line nub w/ a clamped hose. Fill reservoir w/ ATF. (If two man job, start vehilce and add fluid to keep reservoir full). If one man, remove the the ignition cable from distributor and let the starter turn over the engine a couple times, 5-10 seconds. Fill up reservoir. Repeat until you're getting out ATF fluid from return hose.
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
