Sponsored by: CARiD
Firing problem???
Old Sep 28, 2013 | 08:46 AM
COONDAWG's Avatar
Firing problem???
1994 Toyota pickup 4X4 22re 5 speed manual
I seem to have a firing problem that no one can figure out. when I start the truck cold it idles and runs perfect, no misses or spitting and sputtering. After driving it and warming it up I kill the engine. upon starting it back it idles very rough, rpm dropping to around 500. upon take off it spits and sputters and sometimes blows back through the air breather housing. once I pick up speed, third gear, it smoothes out. it does this every time I kill it after it warms up.
I have replaced plugs, wires, dist cap and rotor, pick up coil, and attempted to set the timing. upon putting the timing light on it and crossing the termimals, when set on 5 the engine idles way too slow, when idled up to a suitable rpm the timing mark is way off the dial.
any suggestions????
Old Sep 29, 2013 | 12:01 PM
thefishguy77's Avatar
Had you checked to see if your tps is in properly. Also could a PO have messed with your idle screw so it's idle is set to low to be properly timed. How close to the ends of your distributor adjustment are you? Close to center or almost out of adjustment when it runs close to ok? Could it be a distributor off a tooth
I'm sure someone who knows more than me will chime in soon?
Sleaker
Aug 26, 2020 06:03 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
256mbaker
Jul 31, 2015 06:45 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
