Sponsored by: CARiD
Diagnostic code 32-air flow meter signal???
Old Sep 13, 2013 | 07:43 PM
Dom2332's Avatar
Hey guys,
Pulled the two codes from my truck after work and got the following. 22 and 32.
22 is the ect sensor and its only $20 so I will be replacing that tomorrow. I am just not sure what to do for code 32 -air flow meter signal. Do you think it's a connection issue, wire issue or afm needs clean and can you clean those.
The issues I'm having now with my truck are hard cold starts and erratic surging idle and sputtering when warm. Truck sometimes won't stay idling after warm if I don't stay on the gas. I'm thinking the ect sensor may cure the cold start problem but not sure on the other problem.
Old Sep 17, 2013 | 07:34 PM
Nebo's Avatar
get some Mass Sensor cleaner and spray it down. Also, buy some dielectric grease and put in the electrical connector. It may help.. How did the ECT Sensor install go?
Old Sep 17, 2013 | 11:35 PM
wyoming9's Avatar
Red face
Your problem could be any or all of those you mention.
The AFM does sometimes fail you won`t know till you do some tests
Old Sep 18, 2013 | 06:11 AM
PlainJaneYota's Avatar
Could be that or a problem with the ECU itself...had that happen before!
Old Sep 18, 2013 | 06:14 AM
Dom2332's Avatar
ECT install went ok, pretty tight space to work back there but got it in! Took care of my cold start issue but still having the rough idle/rich fuel problem when hot. But since I pulled the EFI fuse to reset the CEL I have had no more code 32.
However this morning on my way to work the CEL went on and I checked it when i got in. It is a code 71, EGR system. Now what to do there?? Need to research this now! Think this could be my issue when engine gets hot and runs rough and rich?
Blamalam
Mar 12, 2022 07:34 AM
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
raptor510
Aug 19, 2015 02:15 PM
JHalcyonM
Aug 4, 2015 01:19 PM
