Bad NSS cause tranny not to shift properly? - YotaTech Forums
LinkBack Thread Tools Search this Thread
Old 11-15-2013, 04:58 PM   #1
Question Bad NSS cause tranny not to shift properly?
I have a 2000 Toyota 4Runner 3.4V6 287,000 miles.
my check engine light is on for the 3rd time and the code always says Neutral Safety Switch. Light has stayed on a few days this time vs. going back out in few hours.
My other problem is - transmission doesn't shift out of 2nd gear (auto tranny) when it's cold. once it warms and the viscosity of fluid is smoother or not as thick (this is my guess from educating myself) then 4runner runs fine.
this started in about Feb of this year but as weather warmed up the problem disappeared all summer. So yes, it's normally corrected by letting my 4runner warm up significantly to get the fluid running.
However, lately (according to my 19 yr old son who is driving it) it's not shifting properly even after warming up several minutes. One "solution" -he pulls over, turns vehicle off; let's it set a few and restarts.
I 've talked with three diff mechanics and also auto parts stores. too many diff "opinions" . but basically everyone seems to think the NSS will correct the tranny not shifting problem except one mechanic who said the NSS has to do with the ignition.
I also believe after me researching that I'm learning that the NSS has to do with the ignition and may or may not be related to the shifting of tranny??
however, when the non-shifting tranny problem is going to happen, my reverse light comes on while in D and then i know i'm going to have problem with the tranny.
I saw that the NSS does say something about Reverse light , etc.
So i am not clear if the two issues are connected or not. Specific insight MUCH appreciated.
4-RunnerGal is offline   Reply With Quote
Old 08-04-2014, 06:04 PM   #2
Tranny won't shift when headlights are on
I believe I started this thread last fall - I thought then that my problem was the cold affecting the shifting of my tranny.. and it DOES take a few minutes for my 4runner to warm up in the cold and shift properly - HOWEVER, that's not THE problem. I have since discovered that it's something electrical . My check engine light now stays on - the code ALWAYS says my Neutral Safety switch is the problem.
However, I had the NSS replaced and my 4Runner ran perfect for a few hours that evening. Next evening when I turned on headlights, it was back to not shifting again. So it has for several months, run fine as long as headlights are not turned on. the Check Engine light is on and intermittently the Reverse light is on while I'm in Drive but as long as headlights are off, I don't have the problem. The running lights are always on and I can drive with blinkers on.. but not headlight. tranny won't shift. Any ideas?
Old 08-04-2014, 06:30 PM   #3
rworegon's Avatar
Do you have what the code number that you are getting? It will help if you can share it.
rworegon is offline   Reply With Quote
Old 08-05-2014, 05:53 PM   #4
i don't have code #, but I will check tomorrow. every time I get the code and look it up it says Neutral Safety switch. Thanks for moving me out here in this thread.
To clarify - my 4Runner shifts/runs fine with the headlights off. When I turn headlights on, the tranny wont shift. And also upon turning headlights on, the REverse light immediately comes on while in drive. I can go about 30-35 mph and then the RPM go high and tranny will not shift. Turn headlights off right then, it shifts fine.
Old 01-14-2015, 08:20 AM   #5
Did anyone find the cause of this issue? I just bought a 2000 4runner and I'm having the same issue with it not shifting or when it's warm and I turn on the high beams, it shifts down to first and I have to pull over and shut it off. The check engine light is on and the code is saying neutral safety switch, but doesn't seem like the lights would have anything to do with that?
toyota20004 is offline   Reply With Quote
Old 06-21-2017, 07:35 AM   #6
Did you get a answer?
My toyota will not shift when the lights are on! Did you find out what was wrong with yours? Any help would be greatly appreciated!!!!
Keepur0pinions is offline   Reply With Quote
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 9 05-28-2017 07:51 AM
Please help! smthwsn357 86-95 Trucks & 4Runners 7 04-11-2016 05:22 AM
FS[SouthEast]: BudBuilt Cross-member, Warn Fairlead, Autopal Lights, 4Runner Console,OEM Skid Plate BeMiceElf Misc Stuff (Vehicle Related) 7 10-10-2015 09:40 PM
Write-up: Converting forward shift transfer case to a top shift for crawl box crashburnoveride 86-95 Trucks & 4Runners 1 07-10-2015 06:39 AM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 01:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
