Sponsored by: CARiD
Economy sas build?
Old Aug 2, 2011 | 08:54 PM
brysawn's Avatar
Economy sas build?
I finally got a solid front axle for my 94 pickup to begin my swap. But I'm looking here at the trail-gear IFS eliminator kit and thinking that I can do this for less expensive then a grand. But I've got some questions.
What is the best steering set-up? Can a factory 84/85 steering be used?
What is the best/streetable spring set-up?
How do I go about getting the brakes working, is it as simple as adding extensions or new lines to the factory stuff?
I'll be making a lot of the stuff (like the spring hanger and mounts) and buying most of the stuff as I go. But I'm mostly confused about steering and brakes.
Old Aug 2, 2011 | 08:59 PM
runs-on-4's Avatar
brysawn- its all depend on what kind of build your going
Old Aug 2, 2011 | 09:01 PM
Tofer's Avatar
Sponsor
push pull will not work.. you'll need high steer.
best cheap springs are going to be RUFs
you'll want to use LC roters and your IFS calipers...
I put my SAS by piece meal-ing it together trying to save money (this was before i was a TG dealer) and i ended spending several hundred more than if i just bought the kit and be done with it..
Old Aug 2, 2011 | 09:03 PM
sc87yota's Avatar
I was gunna say the same thing. I've done lots of pricing and the TG kit is inexpensive for what you get! Its a very complete kit.
Old Aug 2, 2011 | 09:10 PM
brysawn's Avatar
Its not the fact that it's expensive. It's just I don't like the quality of some of the parts it comes with. Like the spring hangers.
For my calipers, can I just use the stock 84 rotors, or are they no good? And do I just need to extend my brake lines to compensate for the added height?
Old Aug 3, 2011 | 04:14 AM
waskillywabbit's Avatar
So where have you had a firsthand experience to test said quality?
:wabbit2:
Old Aug 3, 2011 | 04:37 AM
brysawn's Avatar
:wabbit2:
I guess I haven't, so I wouldn't know said quality. Thanks for correcting me on that. I'd rather just build my own
Old Aug 3, 2011 | 04:43 AM
More power to you if you want to build your own stuff. It will take forever and it gets tiresome.
SAS is a LOT of work already. It's nice to be able to just unwrap parts, clean them up, test fit, tack and put things together. I can't imagine having to make everything too. I could but I will never waste my time doing it.
Buy the kit. You won't regret it.
:wabbit2:
Old Aug 3, 2011 | 04:44 AM
xxxtreme22r's Avatar
I'd rather just use something that has already been proven to work without much issue. But then again, I don't ever plan on doing an SAS, If I want a solid axle I'll buy myself an 85 rig.
By the time your done buying steel, welding materials, fabbing, R&D'ing, refabbing again, breaking said homemade parts, buying more steel and refabbing for a third time said parts, you might have just as well bought a kit.
Not to mention all the drill bits, cutting blades etc etc your gonna go through.
Old Aug 3, 2011 | 05:14 AM
87hillbillyoter's Avatar
:wabbit2:
bingo. you never realize how much work it actually is until you do it. i am super happy i bought a kit. even though it wasnt a complete kit
Longbed 90
Mar 11, 2019 12:38 PM
punks_is_4x4
May 31, 2016 06:03 AM
RickyD
Oct 2, 2015 07:53 AM
Flying91
Sep 10, 2015 03:41 PM
seab1209
Sep 3, 2015 05:41 PM
