Sponsored by: CARiD
valve spring
Old Aug 12, 2011 | 12:07 PM
9hpcastiron's Avatar
valve spring
i'm changing valve springs but dont want to remove the head. my plan is to remove the rocker assembly then reinstall the head studs with spacers so i can rotate the crank without breaking the head seal. change the springs and reassemble. any suggestions would be appreciated. thanks eric
Old Aug 12, 2011 | 12:17 PM
scuba's Avatar
Bad idea.
Once you loosen the head bolts you break the head seal.
Do it once, do it right.
Old Aug 12, 2011 | 01:25 PM
xxxtreme22r's Avatar
if your changing valve springs you have to put something in the cyl to hold up the valves which means either 1 compressed air or rope. Both of which will break the seal. Even changing just a cam on these 22r's is risky without doing the headgasket.
nvdesertrunner
May 11, 2020 08:18 PM
he's gone
7
Dec 3, 2019 07:08 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Shagool22
Aug 14, 2015 12:24 AM
cars-guy
Jul 11, 2015 07:51 PM
