Sponsored by: CARiD
22re running rich
Old Apr 7, 2015 | 02:08 AM
Edward mitchell's Avatar
22re running rich
new to the site, live in Northwest florida, hi to all yota owners...I have just put a remaned 1986 22re in my truck...problem is it is running very rich, strange thing the old motor did not run rich I have cleaned the throttle body, replaced the temperature sensor...cold start works great does not leak truck cranks good and idles but after about 5 minutes it starts using more fuel than it needs..really want to fix this can any of you yoga guys help....??
Old Apr 8, 2015 | 07:57 AM
Hoosier2314's Avatar
Sounds kinda like a timing issue. Do you happen to know what offset you used when you timed the vehicle?
Old Apr 8, 2015 | 10:59 AM
DHWRIGHT's Avatar
If you figure it out post up your fix because my 4runner every now and then will run so rich it smokes black for a few seconds then runs fine for a week. I tired, tested everything under the hood to no prevail. mines intermittent so makes it hard to diagnose, but your issues might shed light on mine. As of now I am leaning toward a bad ecu because all other FI components are new or something happened when I removed the EGR when I did my rebuild.
Old Apr 9, 2015 | 02:33 AM
Okay I found my problem my number 2 injector was not pulsating, was basically just shooting a straight stream putting to much gas in, I rewired the injector tested it to make sure it was pulsating, problem solved truck cranks and idles excellent...
Old Apr 9, 2015 | 01:14 PM
DHWRIGHT's Avatar
thanks for posting your solution
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
