Sponsored by: CARiD
E Brake Cable
Old Feb 24, 2015 | 05:48 PM
duskey17's Avatar
E Brake Cable
I got me a new 84 extra cab and all it needs is an e brake cable and assembly. Could someone explain everything i need to get to install a brand new one? Any brackets specifically?
Old Feb 24, 2015 | 08:07 PM
bootscootboogie's Avatar
All pro makes an e brake.. Probably has instructions, just make sure you put the right batteries in!
Old Feb 24, 2015 | 11:40 PM
wyoming9's Avatar
Red face
You might want to crawl under and look!!!
4x4 or 2wd??
Quite different.
Which cable front or rear??
Old Feb 25, 2015 | 05:45 AM
83's Avatar
83
Yeah there's the cable which goes from the hand brake lever to about midway down the underside of the truck. Then there's another, I think, which goes from the mid point, to the rear axle. From the rear axle, one cable goes to the right side, one to the left.
So you need to know which you need. And if the brake has been missing for a while, you may need to do some work to get all the moving parts unstuck. Otherwise you might pull it the first time, and it'll seize on you, in the "on" position, which would be lame.
Toyota sells the cables, as well as probably other parts stores and maybe Rock Auto. Once you know what you need, you can start searching for the part.
Old Feb 25, 2015 | 05:52 AM
83's Avatar
83
Screenshot from Rock Auto
jasonty
41
Dec 23, 2018 01:00 PM
okamikai
Apr 30, 2018 10:19 PM
bfmcelroy
Aug 18, 2015 06:42 AM
corey519
Aug 12, 2015 11:12 AM
CanRunner
Jul 20, 2015 01:29 PM
