Sponsored by: CARiD
Cooling Fan
Old Jun 14, 2015 | 05:44 PM
Cooling Fan
I just bought a 1988 Toyota 4x4 3.0L and it has an electric fan. I am assuming its suppose to have a clutch fan .
Old Jun 14, 2015 | 05:53 PM
rworegon's Avatar
Yes, came with clutch fan stock.
Old Jun 14, 2015 | 05:58 PM
I would like to put it back to stock, the guy I bought it from , wired it through the wiring under dash and I am getting strange thing happing electrically . does any aftermarket place sell the shroud and fan blade for it , I've tried searching but haven't been able to find
Old Jun 14, 2015 | 06:06 PM
rworegon's Avatar
Cooling Fan
Rock auto likely has the blade and even the AISIN fan clutch possibly.
The shield may be another story.
Old Jun 14, 2015 | 06:10 PM
The fan I found doesn't look like the one that should be ( oe ) been trying to find a picture of on.
Old Jun 14, 2015 | 06:49 PM
Odin's Avatar
I would TRY to go with salvage yard items for this. Maybe get a new OEM Toyota fan clutch.
The electric fans most people put into their cars and trucks are a step down from the factory set up and/or are wired poorly.
SOME manufacturers equipped their heavily optioned vehicles with fans that had more blades and or a stiffer fan clutch. This was usually the case with factory Hi-Performance muscle cars too. I don't know if it's the same with Toyota, somebody told me they are all the same but then I read that the A/C equipped trucks.. maybe 4Runners? also had a front mounted electric fan???
Since you're starting from scratch you might as well check, I sure would.
If the cooling demand is greater just add a non shrouded push fan in front triggered off a simple toggle switch.
Old Jun 15, 2015 | 11:17 AM
wyoming9's Avatar
Red face
The 3.0 engines for some reason Had Condenser fans.
I never had good luck with electric fans
I have to Agree with the All Father on this you should be able to find what you need used pretty easy.
That way you have it all from the same Vehicle .
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
128keaton
Sep 3, 2015 05:09 PM
