Sponsored by: CARiD
rear window problem (not the wiper or lock button)
Old Apr 16, 2015 | 11:13 AM
enicol420's Avatar
1992 4runner 3.0 auto
Rear window starts to go down then stops. I took the back panel off and the gear starts to move but then stops. I sprayed some penetrating oil along rails and no help. Is the window off track? Please help, i dont want to have to pay someone if its an easy fix. Thanks
Old Apr 16, 2015 | 12:12 PM
wyoming9's Avatar
Red face
Really hard to tell .
Something could have come apart blocking things.
Might just be a poor connection or worn motor
You should also lube the window regulator as well.
Get a helper get some voltage readings at the motor while it is trying to move.
Old Apr 16, 2015 | 09:07 PM
enicol420's Avatar
Thanks for the advice, ill give it a try.
Old Jan 21, 2016 | 09:32 AM
enicol420's Avatar
Update: with help from my mechanic we found out the window mechanism was rusted enough not to allow the window to work properly. We cleaned it up and lubed it well and now it works fine!
Old Jan 21, 2016 | 01:39 PM
Terrys87's Avatar
I was going to suggest a rusted track. What I do on mine to help stop and prevent more rusting is to coat the track with wheel bearing grease. Sometimes they rot out so bad you have to replace the track and or the wheel that rides in it.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
