Sponsored by: CARiD
need some tire help
Old Jun 21, 2015 | 08:07 AM
bowhunter1640's Avatar
need some tire help
hello I'm new here and I've been through some of the threads trying to figure out what the largest tire is that I can go with on my 96 Tacoma. I'm looking at going from a 15" rim to a 16" rim and I'm good up to there but when I start reading all the numbers that everyone posts for tires I start to get lost. I'm used to the numbers for street tires and getting a little confused with all these other numbers. Anyway what I would like to do is go with the biggest tire I can without having to do any mods as far as a lift kit right now. I have to many other things that I need to do to my truck first. thank you p.s. not sure what gen my truck is so if someone could tell me that I would appreciate it. again thanks for the help
Old Jun 26, 2015 | 08:40 AM
Ott47's Avatar
This site might help. on the right hand side it shows the smallest and largest tires that you can fit on a stock 96 Toyota Tacoma. it is Largest tire size: 265/70 R16
Here is the link so that you can check it out. generally a 30-31 is the largest that you are going to be able to fit without rubbing or a lift.
http://www.wheel-size.com/size/toyota/tacoma/1996/
Also here is a site that converts the tire sizes into more readable format. It can be a pain to figure out what size some of the normal truck sizes convert to.
http://tire-size-conversion.com/
Your truck is a 4th Gen in forum talk I believe.
Old Jun 28, 2015 | 05:20 AM
thank you
Old Jul 6, 2015 | 08:10 PM
BigAxeJack's Avatar
If you plan to wheel it, stick to 31" max. You can probably fit 33" but they will rub with suspension flex and full steering.
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
TOYROX
Sep 4, 2015 06:02 PM
AkitaDog
Sep 3, 2015 09:01 PM
matthew138
Sep 3, 2015 08:21 AM
