Sponsored by: CARiD
Removing the bed.
Old Feb 16, 2015 | 03:57 PM
Jolene's Avatar
Removing the bed.
I am going to be removing the bed of my 1989 pickup so I can access the fuel pump (rather than dropping the tank). I also plan to adjust the emergency brake while the bed is off and replace the muffler / cat (it's easier like this I assume?)
What other maintenance tasks are easier when the bed is off?
Old Feb 16, 2015 | 06:44 PM
Robert m's Avatar
Well, what is it? a 4runner or a truck? there is a difference.
Old Feb 16, 2015 | 06:54 PM
konah's Avatar
Pickup is not a 4Runner.
Old Feb 16, 2015 | 06:59 PM
Jolene's Avatar
It's a pickup, hence the removable bed. I'm a newbie. So many models, so much confusion. This is what the VIN search said
07/1989 TOYOTA 4RUNNER TRUCK (RN101L-TRMDEK)
DLX JPP CND RCB T1 22RE EFI MTM 5F CBU W
Old Feb 16, 2015 | 07:05 PM
konah's Avatar
I understood the post. I've never taken the bed off a truck for repair work. It will all be much easier, especially if you are welding the muffler etc.
Old Feb 16, 2015 | 08:48 PM
dropzone's Avatar
Fossilized
I have pulled beds and dropped tanks.
it isn't bad dropping a tank with a transmission jack.
personally I would rather drop the tank.
why would you need to pull the bed to adjust the e-brake?
Old Feb 16, 2015 | 08:53 PM
Jolene's Avatar
My tank is full of gas, would it still be easier to empty and drop? I don't have to remove the bed to adjust the e-brake, I just figured it would be easier to access this way? My truck is parked on a rocky/gravel driveway and getting underneath can be a PITA.
Old Feb 16, 2015 | 09:43 PM
Terrys87's Avatar
Clean the frame out. I start at the rear of the frame and work my way forward getting all of the dirt out with a high pressure air hose and then flush it out with a water hose after getting dirt out.
Old Feb 16, 2015 | 09:45 PM
Jolene's Avatar
Good idea, thanks!
choppe777
May 16, 2016 08:00 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
old87yota
Sep 9, 2015 12:39 PM
gp66
Sep 7, 2015 08:29 AM
Aaron Logan
Sep 3, 2015 08:08 AM
