Sponsored by: CARiD
2010 Tacoma Chirping Sound
Old Mar 16, 2021 | 08:52 AM
drum6321's Avatar
Hello Everyone! I am having a rough time diagnosing a chirping problem with my 2010 Tacoma TRD Sport. If I pullout slowly it doesn't seem to be as bad, however, if I pull out fast it chirps then goes away.
I can't find any metal to metal contact or issues involving the transmission. It shifts gears smoothly and doesn't slip. Also, it doesn't appear to be a wheel bearing since the sound goes away after you reach 25ish mph.
Any help would be greatly appreciated!
Thank you!
Old Mar 16, 2021 | 09:40 AM
MaK92-4RnR's Avatar
Thank you!
Auto or Manual? If it's a manual, it's the throw-out bearing.
Old Mar 16, 2021 | 10:18 AM
drum6321's Avatar
Automatic
Old Mar 16, 2021 | 01:23 PM
2ToyGuy's Avatar
Does it chirp when you apply the brakes?
Does it chirp when you turn the wheel to the stops?
Could it possibly be a U-joint? Crawl under and wiggle the drive shaft. Does it turn, or move in ANY axis when you do? Are there grease-zerts on the u-joints? Have you tried lubing them well if they do?
Have you checked the thickness of the rear brake shoes. The front pads?
Just throwing ideas out there. I get the so few and far between, I gotta get them out there, before they vanish on me.
Good luck to ya!
Pat☺
Old Mar 17, 2021 | 12:45 PM
gehre's Avatar
snaptube vidmate
Old Mar 18, 2021 | 05:30 AM
MaK92-4RnR's Avatar
Deja Vu?
Old Mar 18, 2021 | 07:15 AM
Tims86Toy's Avatar
Check your serpentine belt and all the pulleys. You may have a bearing going bad in one of the pulleys.
Jooosshua
Nov 5, 2020 03:55 PM
darbtaco11
30
Jan 1, 2013 07:08 PM
Fink
Feb 4, 2010 04:38 PM
yamaboy03
Jan 29, 2010 02:03 PM
SIGMAN
Mar 5, 2005 11:23 AM
