Sponsored by: CARiD
3.slow oil pressure gauge issues?
Old Mar 14, 2021 | 06:43 PM
spraypainthero's Avatar
so i got 95' 4runner 3.0 and my oil gauge has never worked. I noticed the oil pressure sensor connector next to the oil filter was damaged and some ground wires were damaged too. I rigged a spade female connector to fit snug on the oil pressure sensor and repaired the broken ground wires from the body to the frame, I also made another ground from engine block to frame. I started the engine up and no response on the gage? so i checked for power at the oil pressure sensor connector, I'm getting 12v so my wiring is good right? I think my oil pressure sensor is bad .....also not sure if the sensor connection part should spin around? I did some digging through the threads and got this far just need to know if I'm on the right track before throwing 80 bucks on a new oil pressure sensor(p/n 83520 34010). Also I don't wanna go mechanical gauge yet, I'd like to get in some troubleshooting practice to get better at fixing my vehicles.
Old Mar 14, 2021 | 11:01 PM
moto809's Avatar
5 Year Member
Sounds like you need a new oil pressure sensor. No, the parts of the sensor should not spin... it's broken.
Old Mar 15, 2021 | 12:37 AM
thanks moto809 I'm gunna order that sensor and let ya know how it works out.
Old Mar 18, 2021 | 11:44 PM
So the oem oil pressure sensor I ordered on amazon showed up today, didn't look oem compared to the old one but I was pumped to see my oil pressure gauge work for once... so I installed it. No luck, still not reading oil pressure, at first it looked like it was moving but quickly went back past L. I'm gunna dig a little deeper on oil pressure specs, wiring diagrams, and gauge specs. If anybody has any suggestions or knowledge on this issue please reply Thanks yotatechs!
Old Mar 19, 2021 | 04:27 AM
moto809's Avatar
5 Year Member
You said it doesn't look the same. Make sure you got a pressure sending unit and not a pressure switch. Unfortunately, sometimes websites mix up the jargon, but the pressure switch is for clusters that only have a dummy light and will not work with a gauge.
Alaskan91
Nov 19, 2014 12:13 PM
owenskp
Sep 3, 2013 07:08 AM
SUPERMAC
Jun 25, 2012 11:10 AM
PabloA
Feb 4, 2007 12:26 PM
