Sponsored by: CARiD
1976 Chinook
Old Aug 21, 2021 | 06:35 AM
Africk1224's Avatar
1976 Chinook
Hi Guys,
I'm starting to dive into my 1976 Chinook. I want to change out the suspension, what do you guys recommend?
Old Aug 21, 2021 | 08:30 AM
wyoming9's Avatar
Maybe a little Hint just what your Game plan is?? Because of the Age finding parts might be interesting !!
Nothing but hard Surface Roads but for the Campground?
Looking to explore the Back Country lots of seldom maintained roads ??
Hauling the least about of weight but looking for a smooth ride?
Just looking to replace worn out stock parts with new??
Old Aug 23, 2021 | 05:03 PM
highonpottery's Avatar
Wow clean looking Chinook! What's your goal with a suspension swap? Keep it 2wd or go up to 4wd? Too bad yours is a 76 and has to go in for smogs/inspection, because I'd likely want to do an engine swap at the same time.
I have a 75 Hilux and I can tell you right now there's not much you can tinker with on these trucks' suspension unless you go custom. Most people end up lowering these trucks, or go airbag suspension, but I'd assume you're not wanting that with an RV body that's going to see dirt. Without knowing what you want, a chassis swap from a donor vehicle could be a good direction for this, as you'd get both the drivetrain and the suspension. I'd assume the compact frames off a pickup, 1st/2nd gen 4runner/1gen Tacoma might fit well underneath the body. Not sure if it would fit or how much they'd want for one, but a Lexus GX chassis/drivetrain would likely be what I'd be seeking to swap in.
Old Aug 23, 2021 | 07:24 PM
old87yota's Avatar
Welcome to Yotatech!
I love these little Toyota Chinook campers!
As already been stated, what is your goal?
Is there anything wrong with the existing suspension?
Odellt
Nov 17, 2009 06:50 PM
markg1018
Oct 13, 2003 04:19 PM
va97runner
May 11, 2003 03:27 PM
