Sponsored by: CARiD
Engine smoking from head?
Old Jan 3, 2013 | 06:31 PM
Jadri's Avatar
I noticed my 4runner smelling like oil really bad so I popped the hood and saw smoke coming from what looks like the headgasket. Is it possible that the headgasket is broken and blowing smoke? The truck hasn't been running all that well lately, sputters sometimes when letting off the gas and the shakes and idles really rough when its hot. Giving it gas makes the roughness go away. Also idles fine when cold.
Here is a video of the smoke
engine is a '88 22RE
Old Jan 3, 2013 | 07:25 PM
Xeo's Avatar
Xeo
Is your valve cover leaking? If the leak is bad enough the oil can get on the head gasket and exhaust pipe and burn off making it look like smoke is coming from the head gasket, but in reality its just oil being burned due to the extreme heat.
Old Jan 4, 2013 | 04:53 PM
Jadri's Avatar
VC looks fine but I know the oil pump o ring leaks and has been leaking for a long time. The truck has never smoked like this before though. Do you not think its the headgasket?
Old Jan 4, 2013 | 05:15 PM
xcfunrunner's Avatar
That looks like a valve cover gasket, not the head gasket. It is much easier to fix. Just pull off the valve cover and put in a new gasket with gasket sealer and tighten accordingly.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
raiderhawks00
Jul 8, 2015 06:23 PM
