Sponsored by: CARiD
Help with transmission troubles.
Old Dec 19, 2012 | 03:40 PM
Skatehard96's Avatar
I need help with my 1992 Toyota 4runner. It is an automatic trams and has been having some troubles lately. It doesn't like to shift into overdrive, but it will. It gets up to 4000 rpms and stays there for a while before it will shift. All other shifts are fine it's just into overdrive. Today when I was on my way home from work it shifted to overdrive how it usually does but it kept downshifting me as if I were going up a steep hill and then shifting back up( all at a constant throttle). It did this over and over again all the home until I just turned the overdrive off. My o/d light flashes and the check engine light is on. I can't read any codes because the plug on the car is full of gunk. Idk what the p/0 did but it won't read any codes. At first I was thinking it was vss but now I'm not so sure. Odometer and speedometer don't work.
Old Mar 6, 2013 | 11:51 AM
burgessernie's Avatar
overdrive off light flashing
why is overdrive off light flashing? it happend about one year ago and that trans quit pullinggg in any gear
Old Mar 6, 2013 | 12:00 PM
Overdrive light flashes when there is something faulty in the transmission circuits. Like a check engine light for a tranny. I am no expert though. Just my understanding of it.
Old Jan 25, 2016 | 07:37 PM
ElJameso's Avatar
I would check the transmission solenoids. You can test them with a multi meter. I bet that's the problem. Bitch of a job for nothing if that isn't the problem though. ahahah. Here's a video that will show you how to get to them, but not test them. Only replace them. I think they are about $300 from a parts store.
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
