Sponsored by: CARiD
91 4runner ac delete
Old Dec 22, 2012 | 08:33 PM
scrosst4r's Avatar
Hey I'm a noob not here to ask dumb question just wondering if anyone has any links to a thread involving ac delete on a 3.0 I've tried searching but to no avail but anyways Yotatechs been great so far for threads like that i just haven't been able to find one on here. If anyone knows of one on another site or something like that i appreciate it.
Old Dec 22, 2012 | 08:39 PM
rokblok's Avatar
Cut the belt.
A/C deleted.
Unless of course it also drives something else. Then get a smaller belt...
Old Dec 22, 2012 | 08:48 PM
maroon94's Avatar
Originally Posted by rokblok
Cut the belt.
A/C deleted.
^^^ very nice!
Old Dec 22, 2012 | 10:12 PM
scrosst4r's Avatar
Ill take that as a no then. Thanks.
Old Dec 23, 2012 | 05:18 AM
rokblok's Avatar
Give us more specifics. What are you trying to accomplish? You are to cold? To much power taken up by compressor? Condenser causing overheating? A/C brings back hard childhood memories? What?
Old Dec 23, 2012 | 09:36 AM
scrosst4r's Avatar
i have 6 windows for hot days and mine doesnt work anyways. i just didnt know if i would need an idler pulley from a 3.0 without ac or if there and how many vacuum lines in the bowl of spaghetti are associated to the ac system. I know i have an idle up diaphragm for the ac on my throttle body so i am gonna go ahead and say its not just cut the ol belt and get a smaller one. I was just looking to see if anyone had done a thread on it before. When i swapped add to manual hubs it was easy just researched everything i had to do didn't just fly blind.
Old Dec 23, 2012 | 09:50 AM
BigBluePile's Avatar
I just took the belt off.
Old Dec 23, 2012 | 10:42 AM
scrosst4r's Avatar
So you just took the belt off took everything out and never had a problem? If so that's great was just hesitant to do it all if i was gonna run into a vacuum issue or something down the line
Old Dec 23, 2012 | 10:56 AM
niall's Avatar
If you want to actually delete everything to clear up space, drop some weight/etc, Take of the belt, remove the compressor, condensor, drier and fan, chase all the vacuum lines from the condensor to the intake manifold, or where-ever they run, and cap them with vac nipples. Hope that helps!
Old Dec 23, 2012 | 11:06 AM
maroon94's Avatar
I've never messed with a/c on yotas cuz I don't have it on mine and never was asked to look. But, in an a/c system there should be a a/c compressor clutch switch at the compressor that turns it on or off, you could unplug the wires and it be no problem, if it has it, which I'd guess it does
Old Dec 23, 2012 | 01:59 PM
scrosst4r's Avatar
Thats what i was planning on. Getting rid of everything associated with the ac. Just didn't want to run into some sort of vacuum issue afterwards. Was just posting to see if it had been done before and if they had any problems
Old Dec 23, 2012 | 02:22 PM
niall's Avatar
As Long as You cap Every Vaccum port associated, you won't have a single problem.
Old Dec 23, 2012 | 05:29 PM
scrosst4r's Avatar
Ok thanks for the help. Sorry for being the usual noob to yotatech. Lol
Old Dec 23, 2012 | 05:32 PM
niall's Avatar
I don't think there's anything wrong with asking questions. Obviously Search first, but if you come up empty, there's no such thing as a wrong question.
Old Dec 23, 2012 | 06:20 PM
scrosst4r's Avatar
I searched but only thing i could find were build threads where ac delete was discussed. Not like when i searched add delete and found a full write up of everything to do that's what i was looking for when i posted thought someone might have something like https://www.yotatech.com/~corey/tech.../matt_hubs.htm good ole fashioned dummy proof directions is what i was hoping someone had a link to lol.. thanks again
Old Dec 23, 2012 | 08:06 PM
rokblok's Avatar
Now it's on you to do a full write up on everything you did for your A/C delete. So the next noob can search and read what they need to do...
Good luck!!
Old Dec 23, 2012 | 09:45 PM
scrosst4r's Avatar
Haha would do that But if its never been covered before than I'm guessing its never been an issue for anyone. Haha either they didn't have ac to begin with or their ac worked so the didnt mess with it.. i guess I'm the 1/1000000 that has it and it doesn't work
Old Dec 23, 2012 | 10:27 PM
rokblok's Avatar
My truck had it but I removed it cause I like my Toy truck to be a truck. Grew up without A/C, only my wife's vehicle has it. I've never had a vehicle(other than spouses) that had operable A/C. So I always removed everything pertaining to A/C.
Well, I did have a couple of Audi TQ's that had it. But I never used it so it doesn't count....
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
BeMiceElf
Oct 10, 2015 09:40 PM
BrotherAndySLB
Jul 9, 2015 06:18 PM
