Sponsored by: CARiD
1983 22R timing Chain question
Old Dec 8, 2012 | 10:24 AM
87DirtRipper's Avatar
Hey guys. Not sure if im in the right place to ask this question but I recently put a new head gasket in my 83 22r motor. I have the head back on and torqued down. However I cant get the timing chain gear on. Is there a way that I can get it on without taking my water pump, pulleys and all that off?
Old Dec 8, 2012 | 07:48 PM
Dale Rosales's Avatar
get a long skinny pry bar long enough to reach the chain tensioner and push in the chain tensioner. I have done this it works! Good luck
Old Dec 8, 2012 | 07:49 PM
and make sure you do not let go and drop the bar lol
Old Dec 10, 2012 | 12:32 PM
yeah had some trouble. I have a duel timing chain so the bar was real hard to get in there. Then a friend told me to move the crank back and fourth. It went right on. Duh me
Old Dec 10, 2012 | 12:37 PM
Well then we both learned something from this situation lol awesome you were able to get the gear on buddy!
Old Dec 13, 2012 | 08:45 AM
Thanks man. unfortunately i put a new head gasket on. put every thing back together and found out i have a bad head. My oil is chocolate colored. Dang it
Old Dec 13, 2012 | 08:52 AM
That sucks! It's a early 22R head?
Old Dec 13, 2012 | 09:44 AM
nctom's Avatar
That exact thing just happened to me. I had my cylinder head surfaced by a shady machinist. He used a belt sander and the result was unusable. I took it to a better machine shop and the result is perfect. I got to do the head gasket job 2x but I have a solved problem now! It only cost me a new head gasket / head bolts and the cost of quality machining. Oh yea, and a weekend to disassemble / reassemble.
Old Dec 13, 2012 | 10:34 PM
yeah. Howeverrrr I purchased a 22r head about 2 months ago. I got it shipped here opened it up, and put it on. I then realized that my pistons were hitting my head. Looked it up on this amazing website. And BAM! i figured out i have an older 22r motor in it, and the new head had pear shaped ports. The truck is an 87, so somewhere along the lines it was swapped. So now i think ill just find a 85 or newer block and put it in.
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
