89 Toyota pickup buzzing sound
Old 01-07-2013, 05:26 PM
Greasytooth21's Avatar
Hey all, so my pickup has developed another new habbit. Its a 89 22re 4x4 just as a little background. So what it's doing is this really high pitched buzz that only happens within in the frist few seconds of acceleration from a dead stop. It stops right after and sounds like its coming from the steering column. It sounds like something is vibrating on something else like a very high pitched kazoo. The steering and driving characteristics haven't changed, the sound is just very annoying. Any thoughts?
Old 01-07-2013, 06:13 PM
rokblok's Avatar
I'm guessing something worked its way loose and is vibrating on something else?
What did I win?!?
Old 04-26-2014, 02:06 PM
AppalachianOffRoader's Avatar
I realize you posted this a while ago, and might have found the issue. But if you haven't, it might be, and probably is your speedometer cable. It's a fairly common isse with older vehicles in general, not just with yotas. To replace it, you'll have to pretty much strip out the dash. Might as well source some other parts in the area that need replacing too
However, it might also be your horn, believe it or not. Pull off the steering column shroud and you'll see a metal contact ring close to the steering wheel end. Rub some grease or oil on it and see if that stops it. That's an easy place to start. As oppose to ripping out the entire dash.
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Gamble_STi
07-01-2015 12:51 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
paxanders
06-21-2015 06:29 AM
Quick Reply: 89 Toyota pickup buzzing sound
