Sponsored by: CARiD
DUI Distributor 22r Install Details?
Old Apr 25, 2014 | 05:21 AM
manateemilitia's Avatar
Hiya, in my compulsion to visually simplify my engine compartment, I've got a Performance Distributors DUI distributor coming. I've got a 1984 Pickup with an '84 22r.
I've oogled my wiring diagrams and I'm still confused.
Where is the closest spot to connect to the ignition switch? Also, is the coil/igniter assembly completely eliminated?
Secondly, there's only one vacuum line on the distributor. Which one of the two going to the current advance do I keep?
Any help is appreciated, thanks!
Old Apr 25, 2014 | 11:48 PM
gmack192's Avatar
I used the ignition wire off the factory coil. Yes the coil/igniter is eliminated. I used the vacuum port on the bottom of the carb, I have a 38mm Weber on it now.
Old Apr 26, 2014 | 09:23 AM
Thanks for the info, I'm still mildly confused though.
The documentation I've seen indicates hooking up a tach line, but the only one I seem to be able to find is coming off of the igniter.
EDIT: Now that I look at it more carefully, it looks like it's a tach output off of the DUI... right?
Old Apr 26, 2014 | 05:04 PM
gmack192's Avatar
Correct.
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
raptor510
Feb 17, 2017 07:11 AM
jerusry
Oct 19, 2015 05:28 PM
msane99
Jul 11, 2015 08:08 PM
