Sponsored by: CARiD
Rust repair without welding
Old Dec 26, 2012 | 11:57 AM
Rusto's Avatar
I have a pickup bed that's in pretty good shape except for the lower skirt in front of the rear driver's side bed.
I don't have access to a welder, nor do I know how to do so, so welding isn't really an option at this point in time.
What's the best way to fix this? Here are my ideas:
1. Cut the rusted bottom corner section off and bend/shape a piece of sheet metal to get as close to stock look as possible and glue it on with something like this: http://solutions.3m.com/wps/portal/3...beQH8HT14PGTgl
That doesn't really take care of the rust that's in the seam between the rest of the bed side and the skirt and getting the shape right will not be easy for me.
2. Cut off the entire skirt, get all the rust out of the seam and glue a new skirt on there. I haven't been able to find a skirt for this, though. I'd like to do it this way, but I don't know where to find one in Central PA. Would a junkyard just send that skirt to me, you think?
3. Create some nasty, giant bondo/metal netting monstrosity. I'm not going to do this, but felt I should have at least three ideas up here.
4. Have a body shop repair it (I really don't want to do this as it goes against every fiber in my being and against the reason I bought this truck to begin with)
I thought about a fiberglass skirt, but nobody seems to just make the skirt, or a standard bed side for a 84 US body style.
I've learned a ton on this site already and I look forward to the feedback.
Russell
Old Dec 26, 2012 | 12:00 PM
vital22re's Avatar
totally a bro
Pm member slacker, he's up in canada and makes fiberglass replacement panels.
Old Dec 26, 2012 | 12:22 PM
Rusto's Avatar
I hit up Slacker initially. He doesn't sell the 84 US-style bed sides, nor just the skirts. And doesn't know anybody that does.
Thanks, though.
Old Dec 26, 2012 | 12:43 PM
snobdds's Avatar
Just get a new fiberglass bed and be done with it. I have learned the hard way, you fix one section and it will rust in another...meaning you will always be fixing rust. What you will spend in time and money fixing will easilly get you a new fiberglass bed. Your lucky, you have B&G fiberglass right by you and they have a very high quality fiberglass beds.
I went with a new bed last year from them, had to ship from PA to WY, and could not be happier. I wil never worry about my rusty bed again.
Google will come up with their website and you can look through it. Be prepared to wait a coulple of month because they can customize your order and such.
Old Dec 26, 2012 | 11:32 PM
wyoming9's Avatar
Red face
At this point you may as well wait till the winter is over.
Or just order your Fiberglass bed now and install it in the spring.
I would be more concerned with the fuel and brake lines the rusting of the bed is not going to cause as many interesting exciting things as a failed brake or fuel line.
You might be able to find a yard in the Southwest to ship you the parts you need but it wont be cheap.
Take some sheet metal and tin snips cut to the size you need screw or pop rivet .
The seam just clean prime and paint:wabbit2:
Old Dec 27, 2012 | 05:32 AM
Rusto's Avatar
I can't afford to spend what it takes to buy a fiberglass bed or that's the route I'd take.
I will check out B&G Fiberglass, just to dream a little bit.
Actually, I just called them and they sell skins for the '84 US style beds. $290, per. Maybe I'll just get the left skin and replace that whole side. - Thanks for the info SnobDDS. - now, about that toothache I been havin'
It was a SW Colorado truck for the first 25 years of it's life, so the brake and fuel lines are fine. This one section where dirt and road grime was stuck under the plastic piece is really bad.
Old Dec 27, 2012 | 06:56 AM
Rusto's Avatar
Just found this place after doing some random searching in Yotatech:
http://www.alfaparts.net/toyotapu84.htm
Anybody have any experience with these? Maybe this will do the trick.
Old Dec 27, 2012 | 08:15 AM
snobdds's Avatar
Trust me, there is only one solution as I noted above. If you fix that one section, then the section right next to it will rust. You will be just chasing your tail and wasting time and money in the long run. I know you have budget concerns, but fix it once right and it's cheaper in the long run. I live by the principle of...it's too expensive to be cheap.
I have use the alf parts to try and fix my issues and wish someone told me a long time ago to just go fiberglass. The seams don't match up and there is no way so seal the weld seam once there on. They lasted 2 years before they started to rust again...
So your back to where you started, expect your out the time and money on the first fix.
Old Dec 28, 2012 | 01:00 PM
Rusto's Avatar
I'm leaning heavily towards the fiberglass bedside. At $290, I can take care of one whole side. The bed, inside and other bed side are good. This one is the worst with rust you see in the picture, a little over the tire, and some in the back seam.
It's a couple of projects away, but I hope to have a nice "Build Thread" started soon.
Thanks for input.
Old Dec 30, 2012 | 02:15 AM
wyoming9's Avatar
Red face
as long as you keep off the road except for when they are dry you should be fine.
I made the mistake of not using the copper/nickle brake and fuel lines when they needed replaced. the regular steel lines lasted 2 winters till they failed inspection again.
Your bed looks better then my 2000 Tacoma one.
Good luck
nvdesertrunner
May 11, 2020 08:18 PM
young buck
18
Aug 27, 2018 02:40 PM
skoti89
Apr 30, 2016 10:44 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
