Sponsored by: CARiD
wondering any home body lift
Old Dec 19, 2012 | 01:58 PM
Dale Johnston's Avatar
From: Strafford Missouri, right outside of Springfield
Smile wondering any home body lift
I'm planning on making my own cab mount spacers, out of some 3x6 sheets of 1" thick plastic I have, open to criticism but keep I'm mind this is a totalled out beater, but since I'm starting with an idea I saw about using hockey pucks on YouTube, I don't know if I need to modify anything such as my steering column, or just raise the cab, any thoughts would be great......thanksthanks
Old Dec 19, 2012 | 02:06 PM
timothy47129's Avatar
I dont see why it wouldnt work.I have a 2wd so I havent lifted mine but I did change mine to power stering and I would have to say there is enough shaft in the stock steering to slide it it an inch.oh and I just found these body lift install instructions that should help you. http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml
Old Dec 19, 2012 | 02:40 PM
cman1's Avatar
hockey pucks,im not kidding...used em on my 76 chevy,worked great!
Old Dec 19, 2012 | 03:25 PM
waskillywabbit's Avatar
Go for it. Homebrew 3" body lift that ripped every body mount bolt THROUGH the floor pans and the "washers" from a front end collision.
:wabbit2:
Old Jan 11, 2013 | 09:10 PM
rattlewagon's Avatar
Dont do this. The puck breaks down and breaks apart over time
Old Jan 15, 2013 | 02:51 PM
85celicagthatchback's Avatar
just use 2" square tubing and cap one end so the tubing doesnt colapse
Old Jan 15, 2013 | 03:06 PM
CHEEZE's Avatar
I put hockey pucks on my 89 runner. I didnt have to do anything with the steering. I could clear 32s after that.
Old Jan 15, 2013 | 03:50 PM
Dont do this. The puck breaks down and break apart over time
A body lift is 100 bucks. Do it right if youre going to do it.
Hockey pucks are meant for one thing, hockey. They are not meant to withstand the weight of a truck, or be exposed to weather for prolonged periods of time.
Old Jan 16, 2013 | 06:20 AM
Adam F's Avatar
Just buy the kit. How much are you going to spend on getting the pucks, new longer bolts nuts and washers, brackets to lift the bumpers, and radiator and hoses to extend the fuel filler.
The steering shaft is extendable. PITA to get done sometimes as they can be sized together.
Flying91
45
Apr 11, 2024 04:39 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
skoti89
Jul 6, 2015 07:45 PM
